1. Booking now open for the VBOA National Rally 2017!
    Click here for more information.
    Dismiss Notice
Dismiss Notice
LOUD squeak from n/s front wheel
Discussion in 'Mechanical & Electrical' started by GSIVALVER, May 27, 2008.
  1. GSIVALVER
    GSIVALVER
    Feb 28, 2008
    317
    Basingstoke
    Car:
    astra gsi / bmw m3 evo
    Hi guys has anyone ever had this prob i only get it as soon as i turn left from having the steering wheel central iv checked brakes and thats not cause its a really load sqeaking cv joints ok also, iv also just checked the pas fluid and it is really blacky grey so could do with changing job tmoz anyone think this could be cause
    any help will be greatfully appriciated need to fix this asap
  2. Twelfty
    Twelfty
    Apr 19, 2008
    8,560
    Redhill Surrey
    Car:
    Corsa B 1.7 D Isuzu
    could be your PAS pump straining with the fluid so crappy
  3. GSIVALVER
    GSIVALVER
    Feb 28, 2008
    317
    Basingstoke
    Car:
    Pumps on driver side noise i defo n/s and only does it when turning left and not when i turn right would of thought it would do it both ways if that was case, only thing i can think is the rack is clogged on one side so not getting fluid through but its only a guess got our head technician looking tmoz to see if he can diagnose it
  4. Twelfty
    Twelfty
    Apr 19, 2008
    8,560
    Redhill Surrey
    Car:
    Corsa B 1.7 D Isuzu
    let me know how you get on :nod:
  5. GSIVALVER
    GSIVALVER
    Feb 28, 2008
    317
    Basingstoke
    Car:
    Will do just hope its an easy one and not a rack replacement
  6. MarkGSi
    MarkGSi
    May 9, 2008
    2,128
    12
    West Midlands
    Car:
    Astra GTE / Ford Galaxy Tdi / Astra GSi
    I had an loud grating noise that happened just off centre as the car was banking slightly through a corner. This happened left or right and if i turned the steering sharper then the noise would stop. The noise went away in the wet?, turned out to be the guard at the back of the disc catching the disc itself. When i first looked at it there was plenty of clearance but with the suspension travel etc it would rub.
  7. rickisgrate
    rickisgrate Administrator Staff Member Club Member Regional Co-Ordinator
    Oct 20, 2005
    22,776
    149
    kilmarnock
    Car:
    Arctic V6, BMW 320D M-SPORT, ABARTH 500
    check the wishbones bushes as well, had a similar prob with mine a while back and it turned out one of the bushes had collapsed
  8. Bully
    Bully
    Apr 17, 2008
    77
    rochdale
    Could be a dry ball joint (sounds painfull) or even the shocker top bearing
  9. GSIVALVER
    GSIVALVER
    Feb 28, 2008
    317
    Basingstoke
    Car:
    Cheers for help guys il check all that to didnt do it this morning it does sound to high pitch to be a bake plate rub but il look into it still everything poss
  10. savage16v
    savage16v
    Dec 15, 2007
    6,163
    56
    Norwich
    Car:
    Astra GSi MK3 & MK5 SRi XP
    I had a similar problem, and after a while i realised it was the back plate behind the disc rubbing on the disc, worth checking :nod:
  11. GSIVALVER
    GSIVALVER
    Feb 28, 2008
    317
    Basingstoke
    Car:
    Changed steering fluid but still need to flush it though bit more yet squeak went away but it was raining to so being wet might of made it go away to as it seems to only be there when dry. so sat maorning in workshop i think to flush completely replace fluid with new and also new front discs and pads and new wheel bearings to i think and do the lot and just hope that one of them fix it
  12. Twelfty
    Twelfty
    Apr 19, 2008
    8,560
    Redhill Surrey
    Car:
    Corsa B 1.7 D Isuzu
    think after that the only thing it could be is bushes after you done all that
  13. GSIVALVER
    GSIVALVER
    Feb 28, 2008
    317
    Basingstoke
    Car:
    Has already got a new lower arm that side so i cant see it being them but you never know could of been a cheap arm to start with but its only 4 months old
  14. Twelfty
    Twelfty
    Apr 19, 2008
    8,560
    Redhill Surrey
    Car:
    Corsa B 1.7 D Isuzu
    yh the poly bushes are sposed to be good if it leads to it
  15. GSIVALVER
    GSIVALVER
    Feb 28, 2008
    317
    Basingstoke
    Car:
    Noise fixed was changing the brakes and noticed the abs sensor rubbing on driveshaft had alot of corrosion between the steering knuckle and sensor bracket which pushed the sensor into the drive shaft so chisled the corroded stuff out and knocked it back into place with hammer as i couldn't change the bracket as the bolt was seized solid and didn't wanna brake it
    thanks for your help guys im glad i managed to sort it
  16. MarkGSi
    MarkGSi
    May 9, 2008
    2,128
    12
    West Midlands
    Car:
    Well done, thats a nice find for you, its great when you find a nice easy fix for something. If you find that you have to change your ABS sensor soon because it's been damaged, i found that one from a Vectra in the scrapyard works fine.
  17. GSIVALVER
    GSIVALVER
    Feb 28, 2008
    317
    Basingstoke
    Car:
    Should be alright for a while abs light hasn't come on and iv got a couple of spares and new brackets in my garage should i need em that i got from my work
  18. MarkGSi
    MarkGSi
    May 9, 2008
    2,128
    12
    West Midlands
    Car:
    I've had trouble with that bracket rusting and going out of line too. Mine used to flick the TC light on when i turned and was moving slowly at the same time. My ABS sensor eventually broke but when i looked at it the ABS ring, think it's called the reluctor ring?, had been worn away as the bracket was out of line and the sensor was catching. When i fitted the new sensor i had to add a couple of washers to space the sensor away from the ABS ring. I didn't chance bending the bracket back into place as i feared it may snap but it left the sensor half looking over the ABS ring and half looking over the hub. I was surprised to find it all works fine.
  19. GSIVALVER
    GSIVALVER
    Feb 28, 2008
    317
    Basingstoke
    Car:
    My abs ring is grooved to from the end of the sensor rubbing to but all works ok did think that it would be f***** got couple of the techs to look it over and everything fine so fingers crossed just waiting on the next thing to go wrong now which seems to be a trend at the mo
  20. MarkGSi
    MarkGSi
    May 9, 2008
    2,128
    12
    West Midlands
    Car:
    Keep an eye out that that ABS ring doesn't break and you get a gap appear in it. If it does the ABS gets fooled into thinking your skidding whilst your braking and kicks in. Even at low speed, low braking and dry road the pedal starts to grind under your foot.
Share This Page
