1. Booking now open for the VBOA National Rally 2017!
    Click here for more information.
    Dismiss Notice
Dismiss Notice
vauxhall corsa combo isuzi engine starting problems
Discussion in 'Mechanical & Electrical' started by micky, Jun 14, 2010.
  1. micky
    micky
    Mar 23, 2009
    4,085
    ne1 north east
    Car:
    MK3 ASTRA MR B
    Changed the glow plugs (£50 ouch) to see if it rectifys the cold start issue i have been having the last couple of days.
    I have been told if this fails it could be a non return valve failure. Now what is one of them when its at home and is it a big job to do?
  2. Turboshed
    Turboshed
    Jun 6, 2009
    4,278
    10
    Oswestry, Shropshire
    Car:
    Honda Accord SE 2.0 VTEC
    what exactly are your starting issues mate? and £50 sounds abit steep for glowplugs, ya can get decent ones from Motaquip for about £6 each though the dear ones are £12 a piece.
    • Thanks Thanks x 1
  3. micky
    micky
    Mar 23, 2009
    4,085
    ne1 north east
    Car:
    MK3 ASTRA MR B
    The car was getting its MOT done so i got them to replace them and the plug was about £10 plus vat each.
    Cold starts the van wont start if left more than 6 hours. Takes a good two minutes of constant turning of the ignition to get it to fire up. In the process i have killed the battery and hurt my starter motor.
    I been told it could be some kind of return fuel valve failure and that could cause the starting issues?
    Van starts fine when warmed up.
  4. paul.spencer
    paul.spencer
    Jan 6, 2009
    585
    Waiwhetu, New Zealand
    Car:
    1996 Astra X17DTL
    Hey Micky,
    Just thought I should mention another possible cause of cold start problems on that engine is the valve shims. There's a TIS 2000 tech note that describes a cold start problem caused in the 1.7 Isuzu engine by too low comression. It says there is a "reduction of valve clearance caused by excessive seating of intake valves in the valve seat"...
    Cheers, Paul
    • Thanks Thanks x 1
  5. micky
    micky
    Mar 23, 2009
    4,085
    ne1 north east
    Car:
    MK3 ASTRA MR B
    Cheers paul thats what they said its all jargo n to me i just remember valve return and gapping of valves. They said its a time consuming job also.
  6. paul.spencer
    paul.spencer
    Jan 6, 2009
    585
    Car:
    1996 Astra X17DTL
    Sounds like a lot of work but when this came up a few times not so long ago I think there were a couple of posts by people who had managed to complete the job fairly easily - do a search on here for "shims" and find out who did it.
    IIRC I think they removed the shims, had them machined for a couple of pounds each and all was good after refitting them....
    • Thanks Thanks x 1
  7. Turboshed
    Turboshed
    Jun 6, 2009
    4,278
    10
    Car:
    Top man Paul :)
    Tbh, I've not know these engines to have many problems, and easily do over 300k.
    But Paul is usually right. I would have said maybe issues with the stop solenoid on the pump, but it starts fine when warm it just cold starts being the issue
    • Thanks Thanks x 1
  8. paul.spencer
    paul.spencer
    Jan 6, 2009
    585
    Car:
    1996 Astra X17DTL
    LOL, nah just repeating stuff I heard on here. I guess I'm just somewhat obsessed with these diesel engines, both the GM (like mine) and Isuzu...
  9. Turboshed
    Turboshed
    Jun 6, 2009
    4,278
    10
    Car:
    Lol, its the MPG's (K/litre) that you like i think Paul.
    As to the starting issue, I am not convinced it is low compression that is causing the poor coldstarts, as there will be less compression when hot, yet it starts fine. Also how long are you actually leaving it after the glow plug light has gone out?
  10. paul.spencer
    paul.spencer
    Jan 6, 2009
    585
    Car:
    1996 Astra X17DTL
    Hey, this may sound stupid but rereading the thread from the beginning I was just wondering it could be as simple as that common problem of air leaking into the fuel filter on standing - you know, it then requires heaps of cranking to get it going. Warm starts easier because fuel filter is not yet full of air again.
    Just sounded a bit like that kind of problem people have described. You didn't happen to check or change the fuel filter before this problem showed up did you? Might be worth checking the fuel filter (and maybe just install a new one), particularly after standing several hours or overnight. See if it is completly fuel of fuel as it should be. Don't give me a hard time - I just reckon it would be good to rule out an air leak problem before getting into more expensive...
    (And you are absolutely right there Turboshed, my old Astra is by far the cheaper car to run at this point which means a lot to me!)
    • Thanks Thanks x 1
  11. Turboshed
    Turboshed
    Jun 6, 2009
    4,278
    10
    Car:
    That's a good point actually Paul, one I didnt think of, cracked housing or damaged seals on the diesel filter, that would cause bad starts as it needs to draw more fuel into to displace the air. As suggested, replace the filter and see it that cures it. Also check your fuel system for any leaks or splits in the pipes as that would let air in and so cause problems.
    Haha, its all about cheapness eh Paul, gotta love it :). Mate of mine runs a Commodore VY (5.7L V8) and he gets 100km to 13 litres i think. works out about 22mpg here. recently myself did a few longer trips and got a healthy 52.6 mpg (estimated) which is still good for an old car
  12. big e
    big e
    Oct 22, 2008
    13,906
    116
    Leeds
    Car:
    5dr Astra LET, E46 330d Daily.
    Have you tryed changing the glow plug relay?..
    • Thanks Thanks x 1
  13. paul.spencer
    paul.spencer
    Jan 6, 2009
    585
    Car:
    1996 Astra X17DTL
    that's a good point too big e. never asked about glow plug indicator light or maybe putting a meter on the line to the glow plugs...
Share This Page
