Dismiss Notice
X20XEV Cometic Head Gasket???
Discussion in 'Mechanical & Electrical' started by Mr.Negative, Jun 16, 2010.
  1. Mr.Negative
    Mr.Negative Club Member
    Jun 25, 2009
    9,442
    112
    Chesterfield, Derbyshire
    Car:
    Vauxhall Astra GSI Phase 2
    Does anybody know where to buy performance head gaskets for the X20XEV? I know that the X20XEV's seem to suffer with the head gaskets. Hmm... or would I be better getting a GM one? Basically... anybody got any recommendations on head gasket? Oh yeah... is it worth getting uprated head bolts too??? engine isnt going to be mad, hope to have sport cams but everything else internal stock...
  2. Max
    Max
    May 10, 2007
    4,567
    Derby
    Car:
    MK3 V6 - MK5 Estate
    Go for a payne headgasket as I heard some good things about them when I changed mine and havnt had any issues since. Dont reuse headbolts whatever you do, get new ones. Didnt know there was any such thing as uprated headbolts, but I may be wrong.
  3. Mr.Negative
    Jun 25, 2009
    9,442
    112
    Car:
    Yeah... I know not to use them again - stretch bolts. I'm sure somewhere I've seen uprated ones?? hmm...
  4. Rusty
    Rusty
    Mar 16, 2009
    3,094
    Portsmouth
    Car:
    2.0 Pineapple
    The only uprating you can do with the headbolts it's to replace them with reusable stud/nut kits.
    For what it's worth I used a cheap eBay top end gasket and bolt kit when my C18XEL's head gasket went (relevant as they're nigh on the same) and it was fine.
  5. Mr.Negative
    Jun 25, 2009
    9,442
    112
    Car:
    Yeah? hmm... seen the kits for something like 20-30 quid but didnt know if they were worth it in the long run. Not had any issues you say? Maybe just go with a cheap kit then I guess
  6. Rusty
    Rusty
    Mar 16, 2009
    3,094
    Portsmouth
    Car:
    2.0 Pineapple
  7. fennyLET
    fennyLET
    Aug 31, 2007
    4,905
    King's Lynn
    Car:
    Astra mk4 gsi, Astra mk3 gsi turbo
    A c20xe cometic gasket is the same iirc Well i was using a x20xev block, c20let head and cometic.
  8. philip2
    philip2
    Nov 12, 2006
    113
    hawarden/chester
    Car:
    corsa gsi, mini
    just get a goetze gasket, the cheap gasket sets really are cheap and ****e. i had a lad bring a c20xe headset to me and i just laughed and binned it there and then, the gaskets were so poor. do the job right and get the proper oem gasket and bolts.
  9. Mr.Negative
    Jun 25, 2009
    9,442
    112
    Car:
    Is that correct? so the C20XE head gasket is the same?
  10. fennyLET
    fennyLET
    Aug 31, 2007
    4,905
    King's Lynn
    Car:
    That bit is as i was doing it. If the blocks are the same then the heads must be the same.....
  11. Mr.Negative
    Jun 25, 2009
    9,442
    112
    Car:
    Hmm... need to know for sure, would be great if they did fit.
  12. Mr.Negative
    Jun 25, 2009
    9,442
    112
    Car:
    [​IMG]
    They're different
    [​IMG]
    C20XE
    [​IMG]
    X20XEV
  13. fennyLET
    fennyLET
    Aug 31, 2007
    4,905
    King's Lynn
    Car:
    only one pic working
Share This Page
