5 stud conversion
Milton Keynes
Hello,
Please could you let me know what i need to convert the wheels to a 5 stud as i really fany some vectra gsi wheels.
Is it an expensive mod?
Dan
Use search button mate been covered loads recently
you need cav/cally v6 or turbo front legs and use your astra shock inserts with top mounts.
on the rear its easiest to use cav v6 rear hubs as they are a direct replacement for the astra rear hubs
vectra rear hubs can be used but need modifying to fit correctly
it cost me about £150 to do conversion that was using v6 rear hubs, cally front legs, and new 284mm discs and pads
iirc zafira rear 5stud rear hubs/ drums fit
Oh and you are only down the road!!
yeah my offices are in milton keynes on mid summers boulevard so meeting you somewhere is not a problem.... if your interested then i can get all the parts sorted the fronts have just had brand new wheel bearings and hubs they were taken from a calibra turbo and the rears are from a cav v6.
Have a question, what about doing this to a small block engine, as I thought that the differences between small and big block hubs were the size (IE Big block are bigger), If i grab myself some Calibra front legs using obviously the astra shocks springs and topmounts, but would the drive shaft work in the hub ok??
Saab 93 brakes fit, they are 5 stud. I got some off a 2.0 the fronts are 284mm and the struts are the same as cavalier. The rear hubs bolt sraight on aswell :nod:
93s will be 288mm same as post 96 900s.
You can possibly use Astrag F17 inner CV joints, as they are used with big block outers for the 5 stud application.
Depends on the shaft splines compared to teh AstraG shaft (which is too long for a MK3)
