abs pump
bristol
right is there anyway of testing my abs pump as i dont think its working when you press the pedal its rock hard but when i crack the pies off the top that goes from the master cylinder to the pump unit the pedal will go to the floor but put them back on it gose rock hard so i was wondering if there is a way of testing it thanks 4 any help o and i forgot its a 2.2dti vectra 2003 plate that i picked up 4 300 squid
Lincolnshire
It will go hard if the engine isn't running.. and simple.. slam on the brakes (in a safe place).. if wheels lock up, it aint working.. if you feel the pedal judder then it is.
bristol
even with the engine goin you cant push the pedal and i ve changed every thing eles so really its the only thing left its not safe to even try and drive to the local dealers
bristol
all checked and a whole new servo put on it mate thats how come im stuck
bristol
sorted now it was a combo of 2 things brake lines callapsed and the slave cylinder was ****ed so changed it all over and all is good now
