abs sensor mount front leg
i've had a bit of an incident and while changing my bottom ball joint i have snapped my abs mount out of front leg! Hard to tell cause it's so rusty but it kinda looks like the mount itself is held in with 2bolts, mayb 1 from the back, and 1 from the front, behind the disk? Can anyone tell me if i'm right and if i can get another without changin the leg, cause i really can't be assed!
The sensor mount is held into the leg by one bolt, so it just unbolts from the leg as long as the bolt isnt rusted up.
one bolt and 1 pin.
the pins often break off on the metal brackets, newer ones were plastic and almost as likely to break off.
Drill out the remains and fit a new one.
