Astra Estate 1.6 8v to 1.6 16v Echotech coneversion
South Africa
Hi guys new here.
I am trying to find out what type of tachometer is in the Cluster of my Astra .. its a F(92).
Reason needing to find out is, i need to connect the Tachometer and the Temp gauge to my After market ECU.
The ECU i am using is a Spitronics Orion 2 Advanced.
Is it a Magnetic Pickup or a Digital Tach?
Would i even be able to get it to work. Seeing as i junked the old ECU and loom of the car.
Then does any one have a wiring diagram for this cluster?
Thanks and sorry for all the Questions on my first post.
Regards
Lincolnshire
Hello and welcome to the club :)
The original tachometer is a digital output from the ECU. So you will have to use the RPM output from your aftermarket ECU if it has one. If it doesn't have one then I'm not entirely sure how you will be able to connect it up, it might require some creativity with an Arduino unit or something maybe.
