Good day everybody.
I am at my witts end here and really need some input. From 2017 to 2019, I was driving 3000+ Km's every 2nd month. The very last trip I had to do in 2019 is where this issue started. The car was running fine up to the point where I arrived at my destination, where it was stuttering and shaking a lot out of the blue. As a result I replaced the following the day after:
MAP sensor
TPS sensor
ICV
Coil pack
Bougi cords
Plugs
I also did a service again which was the second service in a weeks time, just to be thorough.
The issue initially seemed to be fixed but one issue remained and persisted since 2019 and is still happening today. The engine dips. When cruising you feel it more prominently where you'll be cruising along and it has intermittent jerks/misfires. When stationary and just idling, it idles smooth at first and then you hear the dip in the engine. This happens hot/cold. The only time you don't feel it is when you floor it. Fuel consumption at 13km per liter which is very good. Compression on all cyl. 350psi
Since then I have rebuilt the engine 3x times and I'm currently 70thou oversized. The last rebuild I replaced EVERYTHING. Crank, cam, rockers, tensioners, pumps, lifters, belts etc. I am very confident that there are no mechanical faults unless the gearbox can cause it? I have opened up the gearbox and inspected all the gears individually, replaced all the seals and the gearbox works seemingly well. I have done the clutch kit multiple times. I have replace ALL sensors multiple times. This includes the temp sensors and knock sensor. I have replaced the fuel pump multiple times. I have replaced the Bosch Motronic ECU. I have replaced the injectors, albeit I did so using second hand ones as they are so bloody expensive here I just simply can't afford them. But I have checked the spray patterns and they all appear to be functioning accordingly.
Just last week Thursday, I opened up my wiring harness AGAIN. I disconnected every plug and tested each wire individually for continuity and also possible shorts. I have no doubt that the wiring is indeed good.
I have not replaced any relays but I have tested them each individually while in operation and they do not give any issues/ breaks.
What am I missing?
Just a note. As far as I understand, in South Africa, they never built in the cats and left out the lambda sensors. replaced by very specific resistors in the configuration of a voltage divider. I have tested these resistors and they are still giving the rated Ohms.
Edit:
Also The engine light does come on when this happens. Using the paperclip method I get error codes 73 and 74 at the same time which is Airflow senor High voltage and Airflow sensor low voltage. Because there is no airflow sensor it falls on the MAP sensor but I fail to understand how it can give high and low voltages at the same time. As mentioned before, I have replaced the MAP multiple times and checked the wiring multiple times.
MAP sensor
TPS sensor
ICV
Coil pack
Bougi cords
Plugs
What am I missing?
Edit:
