• 2020 Official MK3OC Calendars now available to pre-order in the club shop!
    **LIMITED TIME REMAINING, ORDERS CLOSE THIS FRIDAY 6PM - ORDER NOW TO AVOID MISSING OUT!**
    Click here to buy now.
Astra Mk3 Phase 1. Windscreen Wiper Linkage Broken Again.
myastra
Pinner Middlesex
Windscreen Wiper Linkage Broken again for the second time. I guess a common problem as the mounting plate for the motor has completely broken away yet again. Same place.
I think last time i replaced it the secondhand one i fitted already started to crack but had problems sourcing that one so i had to fit it.
Can you get good/new replacements or has anyone got a spare i could buy from you ?
bucks
astranaut
Colwyn Bay
I remember the one on mine going deep in Snowdonia during a decent downpour, having to drive back slowly using a wiper blade out the window till I got somewhere with signal. Is it a common problem then?
myastra
Pinner Middlesex
This will be the second time i have changed mine, and on both occasions they have cracked across the motor attaching screws causing the motor to break away.
Thank you both for the help above. I will let you know how i get on.
Also i too would like to know if this is a common problem with the wiper mechanism.
bucks
That's the only wiper linkage listed on Vauxhalls parts catalogue for rhd astra mk3 so i would say so.
So when you say it broke the mount, did you replace all the parts last time? motor and leakage and mounts?
