base tube help
Newport, South Wales
hiya all I've came across a bit of gas pipe its 28cm wide 50cm long and a 1cm thick would this be ideal as a home made base tube.If so i think a 10" sub would fit if Ive calculated it right could some kind member please help me with a bit of advice and information. if i need it longer i can possibly get another piece thanks for viewing
:nod::beer::beer:
dorchester dorset
a 10" sub generally requires 1.5 cubic ft for a sealed enclousure so it would need to be approximatly the 50cm legnth off the top of my head!!!
as for the far end blocking off, use 12mm mdf birch ply or mdf set inside the hole glued in with fibrglass resin then screwed on the outside all the way woruns, screws 3" apart!!then add another 12mm thick layer over the top of the blocker glued on with wood glue then scew through the end into plastic at 12, 3 , 6 and 9 o'clock positions!!
been there done that hehehe
bear in mind sub boxes are square for a reason, ;)
heres a pic any good what do you think ill be cutting the metal bit off the other end
dorchester dorset
leave that on there,,, will make an easy way of supporting it and rolling all over your boot
There's no need as im making brackets for it to be held on the back of the rear seats.
can you post piccysof the finished item? Quite interested in what it looks like finished!
Cheers
I'll have to get back to you mate as i don't know if it been thrown out from where i was storing it :doh: i'll find out today mate:beer::beer:
