Blaupunkt 300
Lancashire
Hi when i turn the ignition on and hold the 2 buttons it bleeps but the clock display stays the same
ive used 1-4 to enter the code then hold the button until it bleeps but no audio
Do you get any display showing?? Radio station etc? If you have enterd the code wrong or wrong code it wont do anything is it the original unit?
The display is diffrent in other models and will need to be changed think it was button 1+3 or 4+6 to swap from 8/10
Check serial number is correct for code etc to
