Blaupunkt Car 300 Speaker Support
Turkey&Bulgaria
I searched trough google but i can't find any information about Car 300's Speaker Ohm and Watt, i only found the gm speaker is 4 ohm.
So i like the original radio i don't want to change, my stock gm speakers are in bad condition right know not like the time when i bought the car can i install new pair off speakers does it burn radio?
And by the way i bought 2 transmitters for listen via bluetooth but they didn' worked with cigarette lighter socket does anybody have experience with this:)
thanks
4 Ohm is pretty common for speakers so probably best to stick to them. Replacing the speakers with 4 ohm speakers shouldn't bother the radio at all, even if they're higher wattage.
Does your cigarette lighter have power going to it? Be worth checking the fuses. Might also just be dirty contacts inside as they can often corrode.
Cigarette lighter is working sir, it's looking good i dont see any corrode and im not a smoker too im the first owner , but i bought a phone charger like 4 years ago its working but i need to turn the device and find the spot where works its hard but once i find the spot its working but this fm transmitters are not , can this socket maybe bigger than any other cars i plugged this transmitters to a toyota corolla 2009 and they just worked fine also thanks for speaker answer ✌ im gonna buy a new set
Also i can record and upload a video about cigarette lighter socket sir
