c20xe coolant leak, inlet manifold?!?!
well the astra is leakin coolant again, doesn't look like water pump, and ive just fitted a brand new genuine item less than 600 miles ago
now there is crystalized coolant all around the final nut on the inlet manifold, timing end, i know there is another chamber in the inlet manifold, besides the 4 inlets, molded onto the end of inlet 4 there is 2 holes, like an in and out, does this carry coolant?!
if so im wonderin if this is where my coolant is leakin from, is a very slow leak and is on the alternator, and down the back of the block.
idea chaps
Yes coolant flows at that end of the inlet manifold.
cheers, reckon this will b worth a good go then!, get a manifold gasket wen i get paid, there is a new 1 on there, but i did get it from auto vaux n everythin else they have ever done has been crap lol
Norfolk
also check the hose off the back of the water pump, they like to split, I have seen a few with a pin hole leak which sprays a very thin (and hard to see) line of coolant over the surrounding components.
