Unless your going to uprate everything then buy a let.But if your going to buy better rods/pistons ect then be better off starting with a xe and building it up.
However what your doing is pretty much making a LET using an XE block, they share the same parts, just various little differences, such as pistons cams, inlets etc etc.
if you got your hands on a knackered & complete LET (so easy to find ) it could be done easily.
put it this way you need a c20let loom, ecu, pistons, rods, fuel reg, injectors, turbo, amel valve, intercooler, boost pipes, tophat etc etc
all that is good to you from the xe is the block, alternator, starter.
your better off buying a complete c20let mate unless you got lots of cash and want to buy all the bits seperatly and build a c20xe turbo just using the c20xe block.
oh and another thing you have to do it tap the block for an oil feed to turbo
