I've just done an engine swap from a 92 RedTop GSi to a 95 GSi (presume was Ecotec).
Everythings in ok, all connected up as far as i can tell.
ECU and all wires connected (only have 2 left a light blue & a white red so have assumed these are redundant as the 95 is aircon and 92 wasn't).
All electrics work ok, aftermarket immob disarms as it should.
On turning the ignition on the engine (relays??) click in the engine bay then when you try to start it there's a loud click from the engine and it doesn't turn over.
The engine was a perfect runner when removed.
Any suggestions???
I've got a feeling its to do with the coil but need clarification.
There's a spade terminal on the coil but there's no wire to go on it????? I'm pretty sure i removed this from the 92 car when i took it out but can't seem to find one on the 95 one.
Here:
Also the fusebox/relay in the engine bay are slightly diff....does this matter? Am i missing a green relay???
92 car:
95 car:
Any suggestions???
Here:
92 car:
95 car:
