Hi,
This question is actually about my mk4 astra rather than my mk3 but just want to know if anyone can give me some info on this. As the question states above, can you do a straight swap of a 1.6 engine into a 1.4 astra, as if you were fitting the car with another 1.4 engine, i.e are all the fittings etc in the same place or would it require additional parts or modifications? My car is a 1999 mk4 astra 1.4 16v x14xe, im not sure of the engine code of the 1.6 but I do know that its coming out of a 2000 mk4 astra that was crashed. With regards to the ecu is it possible to do a straight swap from the 2000 astra to the 1999, also i have the original security code off the 99 astra aswel as op-com so if a straight swap wouldnt work could the ecu in the 99 be reset with op-com and somehow reprogramed for the 1.6 engine?? Sorry i know thats a lot of questions at once, thanks for your help in advance
