Car doesn't start/drive well when wet.
Stroud / Cirencester
:hang: basically.
If it's been raining all night (i.e. last night) I go to start my car in the morning and it just doesn't start. Eventually after pumping the accelerator violently and swearing lots it coughs and splutters into action.
The drive is then a bit bumpy but mostly not too bad. What happens is, when I put my foot on the accelerator the revs drop, before it responds and then rises (if that makes sense).
SO, if I'm at a junction for instance, and the car is idling at a 1000 revs, with the clutch down, I put my foot on the accelerator and the revs drop and the car stalls. Then it's back to the whole starting process. Then to pull away I have to touch the accelerator extremely gently, and the revs will drop almost to the point of stalling before rising enough to pull away.
After driving for 2-5 minutes it's absolutely fine. It's not to do with the cold as I broke down in a car wash the other day. Left the bonnet up in the sun for 10 minutes and it was alright.
I have used Holt's Wet Start, but this doesn't seem to make a difference.
swansea
I had a similar problem with my mk3 v6,seemed everytime it rained it would run like a bag of s*** and have no power at all but fine in the dry.Turned out to be a bare wire on my lambda sensor and when it rained the water/sparay would be flicked up on to the wire and cause it to play up lol
Dizzy?! It's a 1.4i, last serviced just over a year ago. Looking back through the reciepts we have:
March 2007 - Recondition cylinder head, replace bottom pulley, replace cambelt, t:rotor distributor, t:cap distributor.
December 2007 - New Coil Spring.
That's the only recent history I got with the car, like 4 months ago.
I'm gonna service and MOT it at the end of next month.
If it starts raining when I'm going along it doesn't affect anything. It's only if the car has been sitting in the rain. Or say if I chucked a bucket of water in my engine bay, then it would happen.
Liverpool
Engine management light on at all when it does the fault ?
Well all the lights come on when you stall don't they. And it's not on when the cars acting all jumpy. I will do a paper clip test asap anyway. I keep meaning too. Where is the plug!? Fusebox, engine bay or passenger footwell, cause I've heard all three.
below the steering wheel, the bucket of water in the engine bay comment made me laugh haha well your service history rules out dizzy as that wot i was thinkin.
i recon could be lamba sensor, not a barewire but prolly just ****in around untill it gets warm
