Can you buy chips for a x20xev like the redtops or is it a no go. Hope iv explained it clearly enough lol
check out google for 'x20xer' u can do a remap of your ecu for the opc x20xer engine, but that also had a differnet head with the irmscher manifold and some other trick bits and pieces which made it pretty quick...
how my cams?knew you would be along to correct me eventuallyhow my cams?
sound so as normal just do the cams, manifold etc and then chip it yea?? How come they dont do a re-map for them anymore??sat in the engine![]()
they only made enough of the cars to get into rallying. I only know of 1 XEV converted to the XER map and thats because the owner had access to the tools to do it and the know howsound so as normal just do the cams, manifold etc and then chip it yea?? How come they dont do a re-map for them anymore??
didnt runat least they're nice and warm then... what did u make a RR out of interest?
very much more hasstle than its worth best getting it done somewhere.you can get chips for these but i think you need to solder them into the ecu board unlike the redtop ones where you just plug in a new epom chip, i could be wrong tho, its really more hassel than its worth best off just getting is setup on a RR and a remap job done,
Kev are you referring to the skunkworkz baby blue mk4 astra??
as that was an xev with the xer remap
)off-topic i know, but whatevr happened to the skunkworkz mk3???
it still goes to billing
Nearly there !!
[/IMG]![]()
