Conversion
Its not worth changing the engine to that. If you going for a 1.6 then go for a C16SE or X16XE(L), much much better engines.
But to answer your question, the only thing you'd need to change is the ECU and the chip in the key for the immobiliser.
oh right, do you think its worth going for 1.8 then rather than a 1.6. I can't stand the performance of a 1.4 so will a 1.6 make much difference? Going from a 2L turbo diesal to 1.4 isnt good lol
Thanks
oh right, i was hoping for something with around 95 bhp, i'l have to have a look about and think. If i went for a 1.8 i would have to get some else to do it which wouldnt be cheap....
Thanks
If only wanting 95bhp, easiest way is to tune yours, is it a mpi or spi, if mpi they have larger valves than the 1.6 version and biggest of the small bore family, and respond awsomely well to porting, and decent cams.
Getting a 1.6 C16SE to 135bhp is childs play, it all fits as std as well, that's what i'm doing to my gf's car, C14SE auto, going to be 1680cc with modded head cam, ecu etc.
