Hi All,
I need to convert my brakes to manual brakes. has anyone here done this before? Any advise?
Cheers
Cheers
Well a track car yes.Guessing rally car?
You'll need a pedal box, Rallydesign do some stuff.
RD3609 - Vauxhall Astra MK1 MK2 MK3 & Kadett Balance Bar Pedal Box from Rally Design
Mounted inline with the brake pedal the box is operated via a single pushrod onto the balance bar housing. Easy to install. Complete with balance bar and cylinders. Through the bulkhead design. This RMD product is now supplied with a double lip sealed R…www.rallydesign.co.uk
As above you require a pedal box. My Astra mk2 track car has a pedal box fitted and the Astra mk3 uses the exact same fittings to give you an idea see my pics below. I bought this kit in 2006 and looks like the company who made mine no longer exist but you could try contacting Performance Car Parts | Racing Motorsports Spares UK | CompBrake as I know they made a very similar setup for the Astra mk2/mk3 and still exist as a company. It's a direct bolt on to replace the servo assist and has in-dash bias adjustment. I run Girling .625in front and .700in rear m/c and the feel and control you get on circuit is amazing but that's also down to brake pad compound and your own setup. My front disks are 285mm (Sierra Cosworth modified) diameter with Hi-Spec 4-pots and Mintex F4r pads (amazing compound) with rears being standard 260mm disks and GTE 16v/GSI 16v ATE 2-pot calipers and any make/model/spec age pad that fits. Don't forget the really important part and that's to use proper dot4 racing brake fluid like Motul600 or 660, you don't need to go at high as Motul700 for a light Astra but choosing the correct spec fluid is paramount.
Thank you very much for this infoAs above you require a pedal box. My Astra mk2 track car has a pedal box fitted and the Astra mk3 uses the exact same fittings to give you an idea see my pics below. I bought this kit in 2006 and looks like the company who made mine no longer exist but you could try contacting Performance Car Parts | Racing Motorsports Spares UK | CompBrake as I know they made a very similar setup for the Astra mk2/mk3 and still exist as a company. It's a direct bolt on to replace the servo assist and has in-dash bias adjustment. I run Girling .625in front and .700in rear m/c and the feel and control you get on circuit is amazing but that's also down to brake pad compound and your own setup. My front disks are 285mm (Sierra Cosworth modified) diameter with Hi-Spec 4-pots and Mintex F4r pads (amazing compound) with rears being standard 260mm disks and GTE 16v/GSI 16v ATE 2-pot calipers and any make/model/spec age pad that fits. Don't forget the really important part and that's to use proper dot4 racing brake fluid like Motul600 or 660, you don't need to go at high as Motul700 for a light Astra but choosing the correct spec fluid is paramount.
I would never want to race a car with a brake booster. You just can't feel what the brakes are doing. having said that. I would never want to drive on the road without a brake booster. Just too unpleasant!!I have been tempted to ditch my OE setup for this you know. How does the pedal box fit inside the car? Or do you have the OE pedals still and this just attaches to the brake pedal? I reckon this could still go to the OE ABS pump too
Internal fittings are the original including the pedal, I can get you some pics inside if you want. Agreed ABS would still function should you wish to keep it. You quickly get use to the pedal feel but it's very weird at first.I have been tempted to ditch my OE setup for this you know. How does the pedal box fit inside the car? Or do you have the OE pedals still and this just attaches to the brake pedal? I reckon this could still go to the OE ABS pump too
DavebGsi you could try looking at uniballs from Super FWD, check out these links as they have offset bjs & full rose joint front arms. I'm sure they could make you something custom to your own spec as well.
