• We have just 2 Official MK3OC Wall Calendars left, find them here in the Club Shop! CLICK HERE
Coolant pipe for 1995 1.7td
UB1 2RX
Hello,
I have a 1995 Isuzu diesel engine hatchback and I'm having no luck in sourcing a replacement coolant hose that runs from the expansion bottle to the engine. Part No. GM 90412657 (degassing hose).
A Vauxhall main dealer parts chap told me that I had the correct part number but that it was an obsolete part.
I've tried eBay, online breakers portals and some direct emails to hose suppliers or businesses that state they hoard old Vauxhall parts... No joy
Have even tried searching using Opel as the manufacturer.
As an alternative I've also tried asking for the internal diameter of the hose for both ends so that I can MacGyver my own replacement! (I don't want to remove the pipe to measure as it's leaking at the bottle end and don't want to risk compromising that end of the pipe until I can swap it out).
Your help & advice will be greatly appreciated.
myastra
Pinner Middlesex
If you have had no luck try a company called Car Builder. They are online. There catalogue is, as the name suggests is full of thousand of bits to build a car. Sure there is something there that would work.
UB1 2RX
Many thanks for your suggestion, I'm awaiting a reply from one possible source of help, if that fails I'll give Car Builder a go.
myastra
Pinner Middlesex
Car builder solutions is worth a try. Having a similar issue with my modified Cortina as i need to replace my lower coolant hose from the radiator to the water pump. Its a modified hose so will be using CBS to provide the parts.
UB1 2RX
A final update on the resolution to my leak problem. I bit the bullet and decided to remove the p up people to get the internal dimensions. It turned out that the coolant pipe was in good condition, instead the plastic pipe that comes out of the expansion bottle had cracked and was allowing a small but continuous at of fluid to leak. So onto eBay and an aftermarket replacement tank and 50 Shades is all sorted (just in time for its 24th birthday!). I've attached some pics to show the problem, don't know if it was wear or caused by mechanics who over the years have caused strain by removing and reattaching the pipe.
Many thanks to those of you who took the time to offer advice.
