Cooling fan relay
Brazil
Hi, i'm having a problem with the cooling fan not turning on and i've checked everything except the relay.
Some friends said that's located on the back of the fuse box but i can't figure out wich one it is. Can someone help me spot it or has a diagram?
Mine is a GLS (C20NE) with AC.
Thanks in advance.
Andy
Member of Honour
London
Without going out the car, I believe it’s the top left most relay.
If you look on the rear of the fusebox cover panel there’s a diagram of which fuses and relays are which.
