custom made alloy oil catch tank
benlee
B&
wiltshire
custom made alloy oil catch tank with one inlet one out let with mini breather filter sight tube and drain bung in bottom.
well used loads of scratches,cuts and dents see pic's but dont leak.
aprrox
hight 270mm (witn breater)
with 190mm
thikness 90mm
http://i5.ebayimg.com/02/i/04/bf/43/11_1_b.JPG
http://i7.ebayimg.com/04/i/04/b9/15/57_1_b.JPG
http://i14.ebayimg.com/03/i/04/b8/e5/c5_1_b.JPG
http://i17.ebayimg.com/03/i/04/b8/dc/3a_1_b.JPG
http://i13.ebayimg.com/02/i/04/b9/11/af_1_b.JPG
£30
benlee
B&
wiltshire
yea connects to any breather but ma need to step up/down the pipe size to match.
on the xe you would conect it to the breater pipe's at the back of the cam cover then block them of on the induction pipe and throttle bodie.
will stop oil and oil/gasses re-entering the engine.
well worth haveing if you drive your car hard or use on the track.
