FAO HID & Trip Computor Owners
Ok fitted my HIDs tonight but as they only connect in 1 headlight socket and the wire runs across the car the check computer says headlight out as the drivers side bulb holder has no bulb in it :sad:
this happened to anyone else? and how did you solve it?
i was thinking stick a relay in the empty one but i havent a clue what size relay :doh:
Kev
cut a wire bit drastic isnt it
Mine does a few wierd things with HID's fitted...
Headlight warning, brake pad warning and puts my abs light on :lol:
Sure does but am not cutting wires... lol infact am slowly making my way round the car sorting out all the cut wires for the trip computer warnings. (washer fluid, water etc).
BTW my hids are hi/lo so all connected up and still does it!!!
Fit a resistor to the empty socket would be the easiest way i'd have though. Similar to what you need to do if you fit LED bulbs
what size tho?
You need to find out what resistance a regular bulb is and you'll need one that matches that
how do i measure the resistance then?
i know that bit and use OHMS but where do i put it on the car to get the reading to get the correct resistor / relay?
You need to measure a standard bulb not the connector, as that's what you need to imitate :doh:
1 side of the MM to the bulb - other to another side of the bulb = resistance?
Resistance = Resistor / Relay needed
then job done?
