Full C25XE running gear
MK3MAD
B&
oswestry, shropshire
C25xe complete engine,
Alternator,
Starter motor,
Air con pump (which you'll need)
F25 Gearbox (which was very smooth with no wines or crunches)
Complete split shafts and bearings,
Fly wheel
Clutch,
Alternator cooler van (working which is rare)
Air flow meter with intake pipes,
PN ecu (non immobilised),
Full wiring loom,
Both exhaust manifolds,
Down pipe,
Inlet manifold,
Ill even give you the gear leaver and inner selector, (reverse is in the towards you and down not away and up)
Im looking for £300 for the lot
im located in oswestry
