Gearbox speed sensor
NEWCASTLE UPON TYNE
I've been trying to remove this from my gearbox ready for taking my engine & box out, it's the last bit i need to disconnect and can't get the bugger out :Cry:
I've tried unscrewing it but the cable coils up and then springs back in the opposite direction, is there a certain way/trick to removing this bit?? :doh:
Are you talking about the speedo cable ??
Look at the gearbox where it is screwed in .. there is a small screw holding the whole unit in the gearbox. Unscrew that and pull the whole cable with small cog drive out as a whole unit.
Thats the yellow bit on this picture:
