As per title.....i got a bit of a problem with my new head unit.... if i take the face off i get a flashing light from the unit as there is still power to it....this is draining my battery and is not good! i know people will say swap red and yellow...only problem with that is previous owner had cut the speaker wires and power + / - and then terminal blocked the new iso plugs on accept they put the ignition and power + into one block. so it kinda goes ---[=== (the [ being the terminal block) i will try and get a pic if u want. Solution i thought was either take the red power one out and put an inline switch on so the power goes but the memory stays when switched, simple enought to do but where would i get a swtich? i can put it under stearing column. Other solution is to work out what one is the ignition from the original block and put that into it's own terminal block....but i dunno if that would solve the problem....
Hope that all makes sence, may be easier to understand with pics but cant find my camera atm
