Help needed
just wondered if anyone could help ive got a mk3 astra had the batterylight and a dim engine management light come on and lost all gages except speedo got no range computer,batery went dead jumped started it and starts now but all probs still the same? is it the alternator? thanks
i had the same problem, when i was going down the road everthing went tits up and the abs light came on dim and everyother light then no brakes .it turned out to be a knackerd battry it was holding the charge but only gave out just short of 8 volt
go to halfords and get a very cheep multimeter ithink about tenner and check the battery
thanks for all your help getting a electritian test it all 2moz seems to only go flat overnight so gna check before buying a alternator!
yea thats what i was thinking person that put the battery on left the plastic cover on someone told me that could of affected the battery-
Doubt it is battery, battery has done its job once the car is started unless you have a lot of ICE.
Check that the belt is tight and that there is no corrosion on the terminals of battery or alternator. You said it discharges over night, do you have an alarm?
Another thing to check. Check that the light comes on with ignition (battery symbol) and goes out once started. If it doesnt light up at all, check it isnt blown. Its a fuse for the regulator and can stop your alternator charging the battery.
If it doesnt light up, start your car and gently rev to around 2.5k. Watch your dash lights, they will get brighter if this is the problem.
Good luck.
