Indicators on mk3 estate
Stalybridge
hello , my sister owns a 1995 mk3 astra estate with a 1.4 8v engine , recently the bulb in the front indicator blew causing the other bulbs to flash faster . So she puts a new bulb in and everything is fine for about ten seconds . im clueless with electrics and wonder what would be the first place to check ???
all help appreciated :anyone_sign:
Newport, South Wales
do they work at all and have you checked the fuses yet mate
Stalybridge
fuses are all ok , ill check the relay , can someone confirm its location ? ( im thinking square black box above fuse box )
Norfolk
When you say they are ok for 10 seconds do you mean it then blows the bulb again ?
If it is ok indicator wise on one side then it isn't the relay, I would have a look for coroded connections on the bulbholder, esp earth.
Stalybridge
thanks for all hints ,
tabetha , they work fine for about ten seconds then blow the bulb , ill check to see what the wirings like
