mk3 astra let 160mph clocks?
hi, does any one know where to buy a signal amplifyer to fit to my abs sensor to make my 160mh electronic clocks work properly? cheers
Liverpool
Go to vauxhall and order part: 13273989 will cost about £12.
Chelmsford, Essex
Pin 2 Brown to ground
Pin 4 Black to ignition
Pin 5 Blue to ABS Sensor
Pin 8 Brown to ABS Sensor
Pin 6 Blue/Red Speed Signal output.
Liverpool
once i get this part where does it go?
You have to find somewhere easy to fit it, when I did mine I put it the plastic relay box thats on the bulkhead near the header tank.
