mk3 van - rear wheels locking under mild breaking?
Redhill Surrey
basicly i'll be driving along not particularly fast or aggressively apply the brakes to slow down and every so often the rear wheels will just lock up entirely, now apart from it eventually ****ing up my tyres, it's also extremely embarrassing making people often stop in the middle on the street to see a "young driver" so to speak and give that "ugh what a pikey look" and it ****es me off
is there a way i can stop this? but without messing up the breaking power when i have the van weighted right up as it really helps to have that kick in
:beer::beer:
djwilde69
North East Co-Ordinator
sunny cattrick :(
all i can think of is if the rear shoe's are really out! or the break pipe's for the frunt are going to the back as it shouldnt happen. id be looking at all the pipe's and shoes/pads
Redhill Surrey
ill be upgrading the front discs and calipers soon as the front brakes are crap
i wonder if the shoes on the back are near the end of their life and are going metal to metal....... the handbrake cable seems to be adequately stiff and latches on well but has a fair bit of travel compared to my hatch mk3 which would also lead me to think the shoes have worn down
i need a dry day so i can check all this out :sad:
djwilde69
sunny cattrick :(
yup! i need to do my hand break soon, id deffo say check it
Redhill Surrey
perfect thanks for the help :beer:
Swindon
yes the vans have a balance adjuster, is the van lowered?
Redhill Surrey
ok thanks sammy ill have a butchers later :beer:
Swindon
on yours its toward to drivers side of the axle. Before you remove it though, im sure it can be adjusted
astranaut
Colwyn Bay
my load sensing valve got stuck on a mk5 escort van, back brakes locked, the first time it did it went up the arse of an MR2 lol. Changed it and it was fine.
Sounds like it is the load sensing valve, had a similar thing on a MK2 astra van, worked better than pulling the handbrake on as long as you were expecting it.
I would have thought that if you just took it off you would get full braking effect to the rear wheels all the time so it would be just as bad. You could fit a manual one that could be adjusted inside the car but it would need new pipes making up and the MOT man might not be impressed.
Redhill Surrey
im not too fussed about adjusting it on the fly i carry a heavy heavy load probably every 12 weeks fro one day from job to job so its only a matter of adjusting it 4 times a year just driving me insane screeching down the road when im only doing like 20 lol
tho it is a good idea for blokes on the move all the time :beer:
It's a bit dodgy as well, doesn't take much to end up facing the wrong way.
I suggested the adjustable valve as there is a very small chance it could be cheaper then the proper one, but it isn't really worth the agro of fitting it.
