- Joined
- Mar 21, 2006
- Messages
- 1,337
- Best answers
- 0
- Reaction score
- 4
- Location
- Cork, Rep of Ireland (Eire)
This is a long story. I was going to change to a 5 stud conversion today but I've come across yet another stumbling block. The pads didn't fit in the calipers, they look the similar but are still wrong, There is a semi-circular part on the top of the pad aswell. So I thought I'd just whip the pads off my other astra that already has a V6 brake set-up (288mm). Took off the caliper and the have the same semi-circular part on top
At this point I think right I'll just use the whole set-up from the other astra(288mm). Went to put the discs on the 5 stud front hubs and the inner part on the back of the discs doesn't fit over the hubs
I was sold what I thought was Calibra 284mm V6 calipers, discs, pads and 5 stud struts.
What I know for sure is:
I measured the discs and they are 284mm.
The PCD on the 5 stud hub matches the PCD on the 284mm discs
The PCD on the 284mm discs matches the 288mm discs
The 284mm discs fit over the 5 stud hub but the 288mm discs do not
Both sets of calipers can be bolted to the 5 stud struts
So whats wrong here people?
Is it that the calipers i've got aren't right?
If the 284mm pads are different to the 288mm pads that might be the problem? Did i get sent the wrong pads?
Are 284mm discs different on the back to 288mm discs?
Are the struts wrong?
Any ideas would be greatly appreciated
