Power Steering Pump Replacement
Hi
Im about to replace the power steering pump on my 1.6
Do i need to change the O rings as the haynes manual says or if that just a bit of back covering on their part?
If so any idea what size/type of o ring i would need?
Norfolk
It's best to change, but so long as the old ones are not hardened or mishapen will be fine.
Are they a special part or should i be able to get from any motor factors?
Norfolk
Most likely a std size o ring, so any seal place or factors should be able to help.
