Reverse lights
people normally suggest the switch on the gearbox although I never had the problem myself, I did have a blown fuse once which stopped them working.
i had this lee, turned out to be a dodgy switch on the box
neva had to change the switch on the box, where abouts is it located ?
its this isn't it
Also as you've got an F28 check the reverse light wiring is plugged into the reverse light switch and not the 1st gear boost cut switch as both use the same plugs and look identical, just in different places on the box
There's one near the top on the front behind the clutch arm and the other is under the box, I forget which is which, if no-one else has said I'll check on the turbo tomorrow for you. I think the top is the reverse light switch though
