I have a genuine Valeo wiper arm off a Citroen ZX used to convert the Astra mk3 to single wiper, had this as a spare but decided to let it go. Comes with undamaged plastic fixing cover and nut. To get the full sweep on your screen you simply need to extend your existing fitting by 10mm that bolts to the wiper motor, fixing hole centre to metal ball centre should be 45mm when extended or there abouts. Then cut the RH wiper arm pivot using a rubber grommet to blank the scuttle and 20 or 21 inch wiper blade and you’re done. I’m only selling the wiper arm as pictured at £45 delivered to your door inc tracking (UK only), go on, you know you always wanted one.
This is the shonkily extended fitting on my wife’s wiper motor (that welding has held firm for 20+yrs!) and how the single wiper looks. You can also have it parking centrally on your screen if your so inclined.
