speedo bouncing
West Yorkshire
I got asked a question yesterday on how do you stop your speedo from bouncing. Its only when they are going from around 0 -30mph. I said i wasnt too sure but id ask on here if it could be solved or its just a wear n tear type of thing.
mine dose the same thing mate 0/30 bounce and i have checked my speedo cable and is right in
There's other things, the clocks? the cable and the speedo driver in the box, i would say its most likely to be the cable, if its frayed at all it will catch and give you the bounce affect, just disconnect it from the box and put the inner cable in a drill and see if it stll bounces while checking for any fray in the cable
its a frayed speedo cable, usually in the gearbox end. If you inscrew the cable youll find its all frayed and probably a pin in the backside to get back in.
