Hey Guys,
Having trouble with my car..again, first off the exhaust has come apart at the down pipe and silencer, not a real problem just haven't had time to sort it and accelerator stuck the other day, had a few bits resprayed on the engine bay and the guy didn't cover the engine up and got clear coat everywhere, so had to take the throttle body and clean the springs and put it back together, has been running fine for a couple of days.
It being mothers day had to go see my mum on the way there it was idling to high (1500-1800rpm usually 800-1000) and on the way back it started spluttering and then the Engine management/ignition light came on, Guessing overrunning maybe because of the exhaust?
Obvious place to start is sorting out the exhaust but is there anything else I should look at to start of with.
It's a C16SE and its recently had its cam belt and water pump changed along with a head gasket change.
Thanks Ash
Thanks Ash
Came in handy on the motorway once.
