does any one know what is causing this and how can i sort it out, it is really hard to change gear.
xhey, thank you to all of you. i will get my bro rite on it haahaa
its not jus first and second any more either its third toox
ok thats looking different, min generally is going into first,
try this,
if difficult gettng into first
clucth down, select 2nd, then push straight up to 1st.
if its better that way, rather than getting into 1st, first
then was told its the sychromesh, i.e. you may have a kancked box
(oooer errr missus)
Although I'm sure your box is perfect,
errrm I mean I bet your box is working fine
i mean errrm cough errrm
<SWING DOORS>
haahaa thanx i think my box is fine tho lol
is it awkward to get to gears under the car..??
i will try to do the gears when engine off but when i go in fifth i do have a problem with the revs increasin and not speed so im thinkin my oil does need changnin.
i wouldnt say it wobbled when in gear tom but what does it mean if it does..?? x
if revs go up when in fifth but speed doesnt then the clutch is slipping and will need changing soon.
sometimes if the gear**** is loose and feels like its not going into gear properly then it can be the gear linkage, but i dont think yours is.
and the engine should stay put when changing the clutch tbh, no need for it to come out
