Selling my single wiper conversion setup as going back to dual wipers for it's next incarnation.
This is a Storm Single Wiper Linkage with straight arm and blade, also has wash/wipe on the arm so don't need the washer jets in the bonnet and it doesn't shoot screenwash over the roof of the car
Linkage will be supplied complete with motor and everything so you can just bolt it straight in to replace yours. You can adjust the park between bottom or middle.
The wiper arm is starting to go a little bit rusty, but nothing a lick of paint can't sort.
The scuttle panel has been professionally smoothed so the 2 sides are symetrical and there is only one hole for a wiper to come through, this has some chips and a crack in the paint where my bonnet has caught it when opening (crappy pattern bonnet
). The scuttle is currently painted black, but would need a re-spray to be mint due to the chips and crack in the paint.
Looking for £80 or would do a p/ex with a standard wiper setup. Can post this but postage at buyers expense
Linkage will be supplied complete with motor and everything so you can just bolt it straight in to replace yours. You can adjust the park between bottom or middle.The wiper arm is starting to go a little bit rusty, but nothing a lick of paint can't sort.
). The scuttle is currently painted black, but would need a re-spray to be mint due to the chips and crack in the paint.Looking for £80 or would do a p/ex with a standard wiper setup. Can post this but postage at buyers expense
Ill have the bits you need
