T reg frontera
Norfolk
I know it's not a mk3 astra, but would like to ask for help on the above.
I must admit I had always(stupidly) looked down on the frontera as not a proper 4wd, but me dads just bought one.
I'm well impressed tbh, changed my view totally, build quality seems very good, it's a 2L ecotec.
Just about to do a new timing belt and tensioners, done oil filter etc, no air con no abs to worry about.
Is it straightforward to do on these and any other tips would be most appreciated, it is a very well looked after one, except for one broken bit, at the front of the engine across the timing belt cover there is a loom in a little cover type bit that clips to the timing belt cover front, this is loose, it looks like it would be a normal breaking problem, as looks a bit delicate clip wise.
Just convincing him to add bullbar and spot lights, already put in LED interior lights as the std ones so dim, and got a K&N filter on way.
Thanks for any comments and input,
