Unknown fault codes??
Cyprus
Hi guys
I have converted my old 10pin c20xe diagnoatics to the late 16pin obd 2 and passed through a diagnostic scanner. I get a bunch of weird fault codes with description "Unknowm fault code" . Anyone faced this before?
Codes are: 03, 840, 810, 850, 830, 730
Cyprus
Right so I have rescanned the ecu and got the proper codes now these are 84, 81, 85, 83 and 73.
73 reflects to low voltage on the amf
81-85 reflect to low voltage on the injectors.
Could the amf issue cause low voltage on the injectors as well??
Liverpool
Afm code 73 is a fault with the signal back to the ecu
Injectors are supplied 12v from the fuel pump relay and are earthed through the ecu
Cyprus
Injectors arent earthed on the fuel rail pal?
Liverpool
Not directly, but the earths on the rail are worth checking if you having problems
