Various bits and bobs Vectra V6, Cav V6 - C20XE
Northampton
Cav bits first,
Due to the rules of the forum lets say...
£100 per item including post. but offers accepted on everything (if you make a sensible offer... i will not reject it) swaps welcome- i have a mk3 with a 3 litre running cav v6 loom/intakes etc so if you have something which may be of use... i'm interested
MAF Sensor
complete throttle body with T/C motor
T/C ECU
Idle control motor
Non-immobiliser ECU
throttle cable
Airinlet pipe (maf to throttle body)
alternator cooling fan motor assy
radiator fan with motor
interior ventilation fan motor assy
dis pack
set of HT leads
coolant expansion tank (inc cap - needs clean)
selection of hoses and breathers
main ABS unit(from under bonnet)
wiper motor and pantograph
pair of wiper arms
headlight switch
t/c switch
indicator stalk (inc switch)
wiper stalk- hatchback (inc switch)
door mirror switch
clock/outside temp display unit
complete instrument panel - 160 clocks electronic drive- 4 pot 7k rev counter
(less than 28000 miles)
alarm sensors x2 (interior)
electric aerial
dash and rear speakers
assorted relays
all interior courtesy lights
interior dash mats
both sun visors (with courtesy lights)
hatchback light clusters -standard vx (pair)
headlights - pair complete with indicators and adjustment motors
(1 carrello 1 lucas)
2 x 15" 6j 5 stud ET 49 offset steel wheels - good condition - no tyres -come with vx wheel trims
wheel brace
both electrically controlled/heated door mirror coloured rojia - need respray
brake shim clip spares - BNB
battery clamp and bolt
Vectra V6 bits
2 x ecu - 1 transponder - 1 key chip (not sure which ecu... will just have to try...)
2 x heads - complete with manifolds - good condition although one may have a bent valve or two
complete inlet plenums inc lower divider NO FPR - some gen Vx new hoses
ported/polished throttle body
v6 downpipes in VGC with both O2 sensors
maf sensor
TPS sensor
v6 SKF (genuine) cambelt kit -BNIB complete with original reciept - paid £75
Flywheel and clutch
F23 gearbox - no idea if it's any good... but apparently came out of working car and selects fine
p/s pump complete with sensor
a/c compressor
cams- complete with pulleys
cam sensor
oil sump(with level sensor)
C20XE - on here on behalf of a friend
complete with flywheel (flat type) clutch to suit f20,18,16 etc
manifolds
loom
ecu
GM type head
DIS type ignition
approx 80k
came from a mk2
Any further details on any of the above please feel free to PM or Email me
Martyn.berry@o2.co.uk
Or phone me on 07515772715
Thanks
Martyn
Northampton
Thought i'd save the best till last... i also have a spare engine mount... albeit a very wierd one, but it's a drivers side mount for a V6... not sure what it's from... and know it will require a little adaptation.. possibly an idler of somekind... pics available on request
£30 collection... bloody heavy, bit if neccesary will send on tuffnells that we use through work and will cost an extra £12
Northampton
Fed up with this lot now,anything i can't use will go to to scrapyard on sunday if not gone. so....
Offers?!?!
bartley green, birmingham
the c20xe is it the whole engine or just spare parts?
Northampton
whole engine - but not mine... he wants £300 for it, he has had it in the dry, covered up for 3 months so he wants it gone.
