- Joined
- Jul 17, 2005
- Messages
- 38,180
- Best answers
- 0
- Reaction score
- 526
- Location
- C:\Uk\Chester_North West
Please stick this please Admin
Borrowed from Astra Sport
Braking systems
Brake Calipers
Remanufactured, Front
C1.4NZ/X1.4NZ - RH R1740035
C1.4NZ/X1.4NZ - LH R1740034
C1.4SE man. to T2500013/T5000073/T8100000 - RH R1740035
C1.4SE man. to T2500013/T5000073/T8100000 - LH R1740034
C1.4SE man. from T2500014/T5000074/T8100001 - RH R1740033
C1.4SE man. from T2500014/T5000074/T8100001 - LH R1740032
C1.4SE auto - RH R1740033
C1.4SE auto - LH R1740032
X1.4XE - RH R1740033
X1.4XE - LH R1740032
C1.6NZ/X1.6SZ/X1.6SZR hatch/saloon man. to T2500013/T5000073/T8100000 - RH R1740035
C1.6NZ/X1.6SZ/X1.6SZR hatch/saloon man. to T2500013/T5000073/T8100000 - LH R1740034
C1.6NZ/X1.6SZ/X1.6SZR hatch/saloon man. from T2500014/T5000074/T8100001 - RH R1740033
C1.6NZ/X1.6SZ/X1.6SZR hatch/saloon man. from T2500014/T5000074/T8100001 - LH R1740032
C1.6NZ/X1.6SZ/X1.6SZR estate/convertible man. - RH R1740033
C1.6NZ/X1.6SZ/X1.6SZR estate/convertible man. - LH R1740032
C1.6NZ/X1.6SZ/X1.6SZR auto - RH R1740033
C1.6NZ/X1.6SZ/X1.6SZR auto - LH R1740032
C1.6SE - RH R1740033
C1.6SE - LH R1740032
X1.6XEL - RH R1740039
X1.6XEL - LH R1740038
C1.8XE/X1.8XE/C1.8XEL - RH R1740039
C1.8XE/X1.8XE/C1.8XEL - LH R1740038
C2.0NE/C2.0XE/X2.0XEV - RH R1740039
C2.0NE/C2.0XE/X2.0XEV - LH R1740038
1.7D/1.7DR/X1.7DTL exc. Sport - RH R1740033
1.7D/1.7DR/X1.7DTL exc. Sport - LH R1740032
1.7TD - RH R1740033
1.7TD - LH R1740032
Brake Calipers
Remanufactured Rear
All models, where fitted - LH R1740026
Brake Cylinders
Rear Wheel
1.4/1.6 to '93 24407364
1.4/1.6 from '94 90498300
1.8/2.0 GT/SRi/Sportive/Cesaro hatch to '92 24407364
1.8/2.0 GT/SRi/Sportive/Cesaro hatch from '93 90498300
1.8/2.0 GT/SRi saloon to NE183174/N5199527/N6999999 24407364
1.8/2.0 GT/SRi saloon from NE183175/N5199528/P6000001 90498300
2.0 exc. GT/SRi/Sportive/Cesaro to '93 24407364
2.0 exc. GT/SRi/Sportive/Cesaro from '94 90498300
1.7D/1.7TD to '93 24407364
1.7D/X1.7DTL/1.7TD from '94 90498300
* Bleed screw may be required 24461620
Brake Disc & Pad Kits
Front (axle set)
C1.4NZ/X1.4NZ, C1.4SE man. to '95 93175465
C1.4SE man. from '86/1.4 16v/C1.6SE 93175472
C1.4SE/C1.6NZ/X1.6SZ auto 93175480
1.4/1.6 Convertible man. 93175480
C1.6NZ/X1.6SZ hatch/saloon to '95 93175465
C1.6NZ/X1.6SZ hatch/saloon from '96 93175480
C1.6NZ/X1.6SZ estate man. 93175480
1.6 16v/1.8/2.0 93175469
Rear (axle set)
Hatch/saloon 1.8/2.0 solid 93182602
Brake Discs/Drums
Rear (single)
1.4/C1.6NZ/X1.6SZ hatch/saloon to '95 90193915
1.7D hatch to '95 90193915
All estate models from '96 24444064
All models except 1.4/C1.6NZ/X1.6SZ hatch/saloon to '95, 1.7D hatch to '95, and estate models from '96, brake drum 90168958
Brake Pads
Front (axle set)
1.4/1.6 (exc. XEL) 90485140
1.6XEL/1.8/2.0 90399495
All diesel models 90485140
Brake Shoes/Pads
Rear (axle set)
Hatch/saloon 1.4/C1.6NZ/X1.6SZ man. 91158363
Hatch/saloon C1.4SE/X1.4SE/1.6 auto trans. 91158366
Hatch/saloon C1.6SE/X1.6XEL/1.8/2.0 91158366
Hatch/saloon 1.8/2.0 disc pads 90485136
Hatch/saloon 1.7D 91158363
Hatch/saloon 1.7TD 91158366
Estate to '95 91158366
Estate from '96 90512792
Brake Lining Wear Sensors
C14NZ/X14NZ/C14SE/X14XE/X16SZ/C16SE 90425491 C18XE/X18XE/C18XEL/C20NE/X20XEV 90335784
C20XE estate 90335784
Handbrake Cables
Hatch/saloon/convertible rear drum brakes 90538698
Hatch/saloon/convertible rear disc brakes 90373855
Estate rear drum brakes 90538629
Air intake.
Air Temperature Sensors
All models from '93 - outside air temp. 9152245
C14SE/C16SE - engine timing 25037370
X14XE/X16SZ/X16XEL - engine timing 12129596
X18XE/X20XEV - engine timing 90499898
C20NE/C20XE - engine timing 90442182
Airflow Meters
1.8/X2.0XEV 90411957
C20NE 90510153
C20XE '92 93178598
C20XE from '93 90510154
Engine
Cylinder Heads
Remanufactured
X1.7DTL R1230051
Camshaft Sensors
1.4 16v/1.6 16v 90412795
C18XE/X18XE/C18XEL/X20XEV 90458252
C20XE 90510656
Crankshaft Sensors
C1.4SE/X1.6SZ/C1.6SE 90451442
X1.4XE/X1.6XEL 90483739
C1.8XE/C1.8XEL 90458251
X1.8XE/X2.0XEV to 14142428 90458251
X1.8XE/X2.0XEV from 14142429 9174621
C20NE '92 90493864
C2.0XE, C2.0NE from '95 90451441
Exhaust Gas Recirculation Valves
C16NZ 17087249
X1.6SZ 17095232
X1.8XE/X2.0XEV 90469560
X17DTL 90540891
Idle Speed Controllers
C1.4NZ/X1.4NZ 17112027
C1.4SE/C1.6SE/X1.6XEL 17113196
C1.6NZ/X1.6SZ 17112031
1.8/X2.0XEV 90411546
C20NE/C20XE 90271799
Knock Sensors
1.4 16v 10456240
X16SZ 10457220
X16XEL to '95 10457220
1.6 16v from '96 10456240
C18XE/X18XE/C18XEL/X20XEV 90411972
C18XE/X18XE/C18XEL/X20XEV (alternative fitment) 90528671
C20XE 90510281
Lambda Sensors
1.4 8v/1.6 8v from T2576508/T5076961 25164596
1.4 16v 25164596
X16XEL to S2531218/S5223656 25163613
1.6 16v from S2531219/S5223657 25164596
C18XE/X20XEV to '95 90411959
C1.8XE/X1.8XE/X2.0XEV from '96 90528253
C18XEL 90411959
C20NE 90397524
C20XE '92 90009053
C20XE from '93 90397524
Throttle Valve Bodies
X14XE 90541440
X16XEL 90541301
C18XE/C18XEL 90411550
X18XE/X20XEV 90541379
Cooling system
Water Temperature Sensors
1.4/1.6/C2.0NE/C2.0XE 90510183
C18XE/X18XE/X20XEV (Kaiserslautern) 90411977
Radiator Bottom Hoses
C1.4NZ/X1.4NZ/C1.4SE 90421906
X1.4XE/X1.6XEL 90540047
1.6 exc. XEL 90421906
1.8/C2.0XE/X2.0XEV 90512956
C2.0NE 90486320
C2.0NE auto (alternative) 90512956
1.7D 90421905
X1.7DTL 90510638
1.7TD 90421810
Radiator Top Hoses
1.4 exc. XE/1.6 exc. XEL, without air con. 90570054
X1.4XE/X1.6XEL without air con. 90509753
X1.4XE/X1.6XEL with air con. 90509917
1.8/X2.0XEV without air con. 90444812
1.8/X2.0XEV with air con. 90444813
C2.0NE without air con. 90570038
C2.0XE without air con. 90570036
1.7D 90421900
X1.7DTL 90570080
1.7TD to P2725381/5272636/8193822 90421901
1.7TD from P2725382/5272637/8193823 90570065
Radiators
1.4 manual steering 90467723
1.4 (exc. XE) power steering to P2768891/P8212506 90412252
1.4 (exc. XE) power steering from P2768892/P8212507 90467723
X1.4XE/X1.6XEL 90443392
1.4/1.6 auto exc. air con. 90412253
1.4/1.6 auto with air con. 52459347
1.6 (exc. XEL) from NA003553/NE127463/N2587473/N4145018/N5030826 90412252
1.8/2.0 90443392
1.7D 90443465
1.7TD to V2127271/V8059680 90353025
1.7TD from V2127272/V8059681 90541496
X1.7DTL 90510645
Water Pumps
1.4 (exc. XE)/1.6 (exc. XE) R1160012
X1.4XE/X1.6XE R1160030
2.0NE to ENG 14608700 R1160018
2.0NE from ENG 14608701 R1160031
1.7TD to ENG 855805 93179363
1.7TD from ENG 855806 93179361
Transmission
CV Joint Boots
Outer - 1.4/1.6 to N4029608 90542771
Outer - 1.4/1.6 from N4026909 90444342
Outer - 1.8/2.0 to P2733477/P5273484/P8202125 90542853
Outer - 1.8/2.0 from P2733478/P5273485/P8202126 90512357
Outer - 1.7D/1.7TD to P2733477/P5273484/P8202125 90542853
Outer - 1.7TD from P2733478/P5273485/P8202126 90512357
Outer - X1.7DTL from N4029609 90444342
Inner - 1.4/1.6 90009025
Inner - 1.8/2.0 92100311
Inner - 1.7D 90009025
Inner - 1.7TD 92100311
CV Joint Kits
Remanufactured
1.4 (exc. X1.4XE) without ABS to P8208330 R1640025
1.4 (exc. X1.4XE) with ABS from P2732834/P3027707/P5271949/P8205046 R1640029
X1.4XE with ABS R1640029
1.6 without ABS R1640025
1.6 with ABS from P2732834/P3027707/P5271949/P8205046 R1640029
1.8/2.0 with ABS from P2733478/P5273485/P8202126 R1640027
1.7D/1.7DR/X1.7DTL with ABS from P2733478/P5273485/P8202126 R1640029
1.7TD with ABS from P2733478/P5273485/P8202126 R1640027
Driveshafts
Remanufactured
1.4/1.6 exc. 16LZ2/16NZ2 - LH R1210038
1.4/1.6 exc. 16LZ2/16NZ2 - RH R1210039
16LZ2/16NZ2/1.8/2.0 - LH R1210047
16LZ2/16NZ2/1.8/2.0 - RH R1210048
1.7D to P2733477/P5273484/P8202125 - LH R1210049
1.7D to P2733477/P5273484/P8202125 - RH R1210050
1.7D/1.7TD from P2733478/P5273485/P8202126 - LH R1210042
1.7D/1.7TD from P2733478/P5273485/P8202126 - RH R1210044
1.7TDS - LH R1210047
1.7TDS - RH R1210048
Clutch Cables
All petrol models 90209336
1.7D 90334418
1.7TD 90373558
Clutch Kits
1.4 8v R1520051
1.4 16v 93185886
C1.6NZ/X1.6SZ R1520038
C1.6SE to ENG 02V78522 R1520038
C1.6SE from ENG 02V78523 R1520067
X1.6XEL R1520053
1.8 to '95 R1520057
1.8 from '96 R1520069
C2.0NE to ENG 14330715 R1520043
C2.0NE from ENG 14330716 to '95 R1520057
C2.0NE from '96 R1520069
C2.0XE to ENG 14128448 R1520054
C2.0XE from ENG 14128449 R1520055
X2.0XEV to ENG 14212513 R1520057
X2.0XEV from ENG 14212514 R1520069
1.7D R1520046
1.7TD R1520060
X1.7DTL to ENG 14102108 R1520070
X1.7DTL from ENG 14102109 R1520053
Exhaust system
Exhaust Front Pipes
C1.4NZ/C1.6NZ 90502736
X1.4NZ 93181140
C1.4SE manual 90502736
X1.6SZ man. 93181140
C1.6SE hatch/saloon man. from N2623644/N4214014/N5130595/NE132801 90448077
C1.6SE estate man. from N2623644/N4214014/N5130595/NE132801 90499225
C1.8XE/C1.8XEL hatch/saloon 90466407
C2.0NE man. 90280144
1.7D/1.7DR from N5169498 exc. cat. converter 90541769
Exhaust Silencer and Centre Pipes
C1.4NZ/X1.4NZ hatch/saloon/convertible 90352301
1.4NZ estate 90541767
C1.4SE hatch/saloon 90352301
1.4SE man. estate 90541767
1.4SE auto estate 90541766
1.4XE man. hatch 93181149
1.4XE estate 93181150
X1.4XE convertible 90570515
1.6SE hatch/saloon man. 90541766
C1.6SE hatch/saloon auto 90352301
1.6SE man. estate 90541767
C1.6NZ/X1.6SZ hatch/saloon/convertible to T2646601/T5116092/T8157683/TB033621 90352301
C1.6NZ convertible from TB033622 90570515
1.6NZ hatch/saloon from T2646602/T5116093/T8157683/TB033621 93181149
1.6NZ estate to S6/S8/SP999999, T2646601, T5116092 90541767
1.6NZ estate from T6/T8/TP000001, T2646602, T5116093 93181150
1.6SZ hatch from T2646602/T5116093/T8157683/TB033621 90541766
1.6SZ estate 90541767
1.6XEL man. hatch/saloon 93181149
1.6XEL man. estate 93181150
1.6XEL auto saloon to S2/S5/S6/SP/S8158612 93181149
1.6XEL auto estate to S8158612 93181150
1.6 man. conv. 90541766
C1.8XE/C1.8XEL hatch/saloon/convertible 93181198
C1.8XE estate 90541784
X1.8XE/X2.0XEV man. hatch/saloon/convertible 93181198
X1.8XE/X2.0XEV auto hatch/saloon/convertible to '95 93181198
X1.8XE man. estate 90541785
C2.0NE hatch/saloon 90352301
2.0NE estate 90541767
2.0XE hatch 90541780
2.0XEV man. estate 90541785
2.0XEV auto estate to '95 90541785
1.7D/1.7DR exc. cat. converter, intermediate pipe 90542952
1.7TD hatch/saloon 90352301
1.7TD estate 90541767
1.7DTL hatch/saloon 90541781
Exhaust Silencer and Tail Pipes
1.4NZ hatch to S6/S8/SP999999, T2646601, T5116092 90410588
1.4NZ man. hatch from T6/T8/TP000001, T2646602, T5116093 90573803
1.4NZ saloon to S6/S8/SP999999, T2646601, T5116092 90410591
1.4NZ LS man. saloon from T6/T8/TP000001, T2646602, T5116093 90573805
1.4NZ man. estate to S6/S8/SP999999, T2646601, T5116092 90411801
1.4NZ man. estate from T6/T8/TP000001, T2646602, T5116093 90531936
1.4SE hatch to S6/S8/SP999999, T2646601, T5116092 (exc. Cesaro/Si) 90410588
1.4SE hatch from T6/T8/TP000001, T2646602, T5116093 (exc. Cesaro/Si) 90573803
1.4SE Cesaro/Si man. hatch 90541778
1.4SE saloon to S6/S8/SP999999, T2646601, T5116092 (exc. Si) 90410591
1.4SE Si saloon 90541779
1.4SE LS saloon from T6/T8/TP000001, T2646602, T5116093 90573805 1.4SE estate to S6/S8/SP999999, T2646601, T5116092 90411801
1.4SE estate from T6/T8/TP000001, T2646602, T5116093 90531936
1.4SE convertible 90541789
1.4XE man. hatch to S6/S8/SP999999, T2646601, T5116092 90410588
1.4XE man. hatch from T6/T8/TP000001, T2646602, T5116093 90573809
1.4XE saloon 90573810
1.4XE convertible to '96 93181175
1.4XE convertible from '97 90570611
1.6NZ hatch 90410588
1.6NZ saloon 90410591
1.6NZ estate 90411801
1.6NZ/1.6SE conv. 90541789
1.6SE hatch to S6/S8/SP999999, T2646601, T5116092 (exc. Cesaro/Si) 90410588
1.6SE hatch from T6/T8/TP000001,T2646602, T5116093 (exc. Cesaro/Si) 90573803
1.6SE Cesaro/Si hatch 90541778
1.6SE man. saloon to S6/S8/SP999999, T2646601, T5116092 (exc. Si) 90410591
1.6SE Si saloon 90541779
1.6SE man. estate 90411801
1.6SE auto estate 90531936
1.6SZ man. hatch 90410588
1.6SZ saloon 90573810
1.6SZ Atlas/Expression estate 90411801
1.6SZ convertible to '94 90541789
1.6SZ convertible from TB033623 to '96 93181175
1.6SZ convertible from '97 90570611
1.6XEL man. hatch to S6/S8/SP999999, T2646601, T5116092 90410588
1.6XEL hatch from T6/T8/TP000001, T2646602, T5116093 90573809 1.6XEL man. saloon from '96 90573810
1.6XEL auto saloon from T5/T6/T8/TP000001, T2646602 90573810
1.6XEL auto estate to S8158612 90411801
1.6XEL convertible to '96 93181175
1.6XEL convertible from '97 90570611
C1.8XE GSi/CD/Cesaro man. hatch 90541786
C1.8XE CD man. saloon 90541787
C1.8XE Diamond man. estate 90541788
X1.8XE man. hatch to S5/S6/S8/SP999999, T2646601 93181151
X1.8XE Sport hatch from T5/T6/T8/TP000001, T2646602 93181195
X1.8XE auto hatch to '95 93181151
X1.8XE estate 90531944
2.0NE CD hatch to S6/S8/SP000001, T2646601, T5116092 90410588
2.0NE CD hatch from T6/T8/TP000001, T2646602, T5116093 90573803
2.0NE CD saloon 90410591
2.0NE SRi/Cesaro hatch 90541778
2.0NE SRi saloon 90541779
2.0NE SRi estate 90411801
2.0NE convertible to PB003966 90541779
2.0NE convertible from PB003967 90541789
C2.0XE estate 90531944
2.0XEV GSi/Sport/CDX man. hatch to S5/S6/SP999999, T2646601, T8157682 93181151
2.0XEV GSi/Sport/CDX hatch from T5/T6/T8/TP000001, T2646602 to '96 93181195
2.0XEV CDX auto hatch to S6/SP999999, T2500013, T5000073, T8099999 93181151
2.0XEV man. estate 90531944
2.0XEV auto estate to '95 90531944
2.0XEV CDX auto estate from '96 93181173
1.7TD hatch to S5/S6/S8/SP999999, T2646601 90410588
1.7TD/1.7DTL hatch from T5/T6/T8/TP000001,T2646602 90573809
1.7TD estate to '95 90411801
1.7TD estate from '96 90531936
1.7DTL hatch to S5/S6/S8/SP999999, T2646601 90410588
1.7DTL estate to S5/S6/S8/SP999999, T2646601 90411801
1.7DTL estate from T5/T6/T8/TP000001, T2646602 90531936
Electrical and Lighting
Alternators
C1.4NZ manual steering to '94 - 55 amp R1030056
C1.4NZ manual steering to '94 - 70 amp R1030058
C1.4NZ/X1.4NZ from '95 man. steering - 55 amp R1030085
C1.4NZ/X1.4NZ/C1.4SE/C1.6SE/C1.6NZ/X1.6SZ man. steering from '95 - 00 amp R1030086
X1.4XE/X1.6XEL - 70 amp R1530001
C1.6NZ man. steering to '94 - 70 amp R1030058
1.4/1.6 with power steering - 70 amp Delco Remy R1530001
1.4/1.6 with power steering - 70 amp Bosch to '92 R1030021
1.4/1.6 with power steering - 70 amp Bosch from '93 R1530001
1.8/C2.0XE/X2.0XEV - 70 amp R1530001
C2.0NE to '92 - 70 amp Delco Remy R1030051
C2.0NE from '93 - 70 amp Delco Remy R1530001
C2.0NE - 70 amp Bosch R1030051
C2.0XE - 70 amp Bosch R1030053
All petrol engines - 100 amp R1530052
All petrol engines - 120 amp R1530053
1.7D/1.7DR/X1.7DTL - 70 amp R1030079
1.7TD - 70 amp to '94 R1030072
1.7TD - 70 amp '95 R1030076
1.7TD - 70 amp '96 R1030093
Batteries
Aftermarket
1.4/1.6 - 44 amp/hr (GM44-T7) 93176572
1.8/2.0 - 55 amp/hr (GM55-T7) 93176576
1.7D/TD - 72 amp/hr (GM72-H3) 93176583
Batteries
OE
All models 60 amp/hr 91158371
All models 70 amp/hr 9201470
Ignition Coils/Coil Packs
C14NZ/X14NZ (ident. XE) (breakpoint info unavailable) 90510386
C1.4NZ/X1.4NZ/X1.4XE/1.6 (breakpoint info unavailable) 10457075
C14SE to 02T14052 (ident. XE) 90510386
C1.4SE from 02T14053 10457075 C16NZ (ident. XF) 90510387
1.8/X2.0XEV 90458250
C20NE (ident. WE) 90350021
C20XE from 14137013 90443900
Starter Motors
C1.4NZ/X1.4NZ/C1.4SE (Valeo) R1040008
C1.4NZ/X1.4NZ/C1.4SE (Bosch/Delco) R1040004
C1.6SE/X1.6XEL (Valeo) R1040008
C1.6NZ/X1.6SZ/C1.6SE (Bosch/Delco) R1040004
1.8/X2.0XEV R1540018
C2.0NE to 14608701 R1040010
C2.0XE to 14154710 R1040010
X1.7DTL R1040028
1.7TD to 997452 R1040023
Headlamps
RH - to S2500015/S5000012/S6000698/R8999999 90442775
RH - from S2500016/S5000013/S6000699/S8100001 exc. GSi 90511097
RH - GSi from T8100001 90442775
LH - to S2500015/S5000012/S6000698/R8999999 90442774
LH - from S2500016/S5000013/S6000699/S8100001 exc. GSi 90511095
LH - GSi from T8100001 90442774
Indicators
Front
RH to '94 exc. CD and GSi 90421896
RH to '94 CD and GSi 90421898
RH from '95 90510959
LH to '94 exc. CD and GSi 90421895
LH to '94 CD and GSi 90421897
LH from '95 90510958
Rear Lamps
RH - Hatch (exc. GSi) to '94 90421970
RH - Hatch (exc. GSi) from '95 90510607
RH - GSi to '94 90421967
RH - GSi from '96 90510607
RH - Saloon/Convertible to '94 90442021
RH - Saloon/Convertible from '95 90510618
RH - Estate to '94 90442018
RH - Estate from '95 90510615
LH - Hatch (exc. GSi) to '94 90421969
LH - Hatch (exc. GSi) from '95 90510601
LH - GSi to '94 90421966
LH - GSi from '96 90510601
LH - Saloon/Convertible to '94 90442020
LH - Saloon/Convertible from '95 90510617
LH - Estate to '94 90442017
LH - Estate from '95 90510614
Service parts
Air Filters
All petrol models 90486883
1.7D 90486883
1.7TD to '95 25069015
1.7TD from '96 90486883
Fuel Filters
All petrol models 25164435
1.7D/X1.7DTL/1.7TD 93183042
Fuel Pumps
C1.4NZ/X1.4NZ/C1.6NZ/X1.6SZ 93187033 C1.4SE/X1.4XE/C1.6SE/X1.6XEL/1.8/2.0 93181359
Glow Plugs (single)
1.7D/X1.7DTL 90510924
1.7TD to ENG 956632 93183738
1.7TD from ENG 956633 93183739
Oil Filters
1.4/1.6/1.8/2.0 93156954
1.7D 90442434
1.7TD 93182630
X1.7DTL 90510935
Pollen Filters
All models 93182435
Spark Plugs (single)
1.4/1.6/C2.0NE (single electrode) (GM30) 90512989
C2.0XE to ENG 14002934 (single electrode) GM3 90442210
All models twin electrode (GM09) 9195109
Wiper Blades
Front driver side 91158286
Front passenger side 90444836
Rear hatch 90444836
Rear estate 90444837
Cam Belt Kits
1.4 8v to O2EC7276/19514224 93188125
1.4 8v from O2EC7277/19514225 93188126
X1.4XE/X1.6XEL 93180219
1.6 8v to O2EC7276 93188125
1.6 8v from O2EC7277 93188126
C1.8XE/X1.8XE to 14102030 93174260
C1.8XE/X1.8XE from 14102031 93174261
C1.8XEL to 14099481 93174260
C1.8XEL from 14099482 93174261
2.0 8v to '95 93188133
2.0 8v from '96 93188132
X2.0XEV to 14406186 93174260
C2.0XE to 14142838 93174266
C2.0XE from 14142839 93174262
X2.0XEV from 14117941 93174261
17TD to '94, to eng. 029078 93188127
17TD to '94, from eng. 029079 93188128
17TD from '95, to eng. 029078 93188129
17TD from '95, from eng. 029079 93188130
Cam Belts
C1.4SE/C1.4NZ/X1.4NZ to ENG 02EC7276 9128723
C1.4SE/C1.4NZ/X1.4NZ from ENG 02EC7277 90531677
X1.4XE from ENG 02EC7319 24451896
C1.6NZ/X1.6SZ to ENG 02EC7276 9128723
C1.6NZ/X1.6SZ from ENG 02EC7277 90531677
X1.6XEL from ENG 20659112 24451896
1.8 to ENG 14102030/14099481 9128726
1.8 from ENG 14102031/14099482 90531682
C2.0NE to ENG 14608700 90410014
C2.0NE from ENG 14608701 9128725
X2.0XEV to ENG 14117940 9128726
X2.0XEV from ENG 14117941 90531682
C2.0XE to ENG 14142838 90410225
C2.0XE from ENG 14142839 90530598
1.7D to ENG 14363651 90410784
1.7D from ENG 14363652/X1.7DTL 90530598
1.7TD 94385561
Distributor Caps
C1.4NZ/X1.4NZ Lucas dist. - Lucas cap 90350997
C1.4NZ/X1.4NZ Lucas dist. - Bosch cap 90350988
C1.4NZ/X1.4NZ Bosch dist. 90350765
C1.4SE 90350997
C1.6NZ Delco 1972927
C2.0NE Bosch 90442358
C2.0NE Valeo 90442011
C2.0XE 90442358
Distributor Rotor Arms
C1.4NZ/X1.4NZ Lucas/C1.4SE 90349877
C1.4NZ/X1.4NZ Bosch 90008612
C1.6NZ Delco 10469006
C2.0NE Bosch 90442356
C2.0NE Valeo 90540398
C2.0XE 90008612
Fan Belts
1.4/1.6 93181708
1.4/1.6 with power steering to '92 93181704
1.4/1.6 with power steering from '93 93181712
C1.6SE 90444312
C2.0NE to '92 90502286
C2.0XE to '92 90502286
1.7D/X1.7DTL 90502286
Steering and Suspension
Front Stabiliser Bar Bushes
16mm 90495054
18mm 90447868
20mm 90495055
22mm 90447867
Front Stabiliser Link Bars
18mm 90278577
20mm 90495045
22mm 90278579
Lower Suspension Arms
Front
1.4, 1.6 hatch, saloon, convertible to R2595225/R5111734/R6036587/R8145949/RB011797 - LH 90495159
1.4, 1.6 hatch, saloon, convertible to R2595225/R5111734/R6036587/R8145949/RB011797 - RH 90495160
1.4, 1.6 hatch, saloon, convertible from R2595226/R5111735/R6036588/R8145950/RB011798 - LH 90495103
1.4, 1.6 hatch, saloon, convertible from R2595226/R5111735/R6036588/R8145950/RB011798 - RH 90495104
1.4, 1.6 estate to R2588487/R5111734/R6036587/R8145949 - LH 90495159
1.4, 1.6 estate to R2588487/R5111734/R6036587/R8145949 - RH 90495160
1.4, 1.6 estate from R2588488/R5111735/R6036588/R8145950 - LH 90495103
1.4, 1.6 estate from R2588488/R5111735/R6036588/R8145950 - RH 90495104
1.8 hatch, saloon estate to R2588487/R5111734/R6036587/R8145949 - LH 90495159
1.8 hatch, saloon estate to R2588487/R5111734/R6036587/R8145949 - RH 90495160
1.8 hatch, saloon estate from R2588488/R5111735/R6036588/R8145950 - LH 90495103
1.8 hatch, saloon estate from R2588488/R5111735/R6036588/R8145950 - RH 90495104
2.0 8v to R2589925/R5111734/R6036587/R8145949/RB011858 exc. GSi - LH 90495159
2.0 8v to R2589925/R5111734/R6036587/R8145949/RB011858 exc. GSi - RH 90495160
2.0 16v hatch, saloon, convertible exc. GSi to R2588487/R5111734/R6036587/R8145949/RB011858 - LH 90495159
2.0 16v hatch, saloon, convertible exc. GSi to R2588487/R5111734/R6036587/R8145949/RB011858 - RH 90495160
2.0 16v hatch, saloon, convertible exc. GSi from R2588488/R5111735/R6036588/R8145950/RB011859 - LH 90495103
2.0 16v hatch, saloon, convertible exc. GSi from R2588488/R5111735/R6036588/R8145950/RB011859 - RH 90495104
2.0 16v estate to R2587415/R5111734/R6036587/R8145949 - LH 90495161
2.0 16v estate to R2587415/R5111734/R6036587/R8145949 - RH 90495162
2.0 16v estate from R2587416/R5111735/R6036588/R8145950 - LH 90495103
2.0 16v estate from R2587416/R5111735/R6036588/R8145950 - RH 90495104
GSi to P2603822/P8146889 - LH 90495159
GSi to P2603822/P8146889 - RH 90495160
GSi from P2603823/P8146890 to R2587415/R5111734/R8145949 - LH 90495161
GSi from P2603823/P8146890 to R2587415/R5111734/R8145949 - RH 90495162
GSi from R2587416/R5111735/R6036588/R8145950 - LH 90495103
GSi from R2587416/R5111735/R6036588/R8145950 - RH 90495104
1.7D hatch to R2591895/R5111734/R6036587/R8145949 - LH 90495159
1.7D hatch to R2591895/R5111734/R6036587/R8145949 - RH 90495160
1.7D hatch from R2591896/R5111735/R6036588/R8145950 - LH 90495103
1.7D hatch from R2591896/R5111735/R6036588/R8145950 - RH 90495104
1.7D saloon/X17DTL to R2595225/R5111734/R6036587/R8145949 - LH 90495159
1.7D saloon/X17DTL to R2595225/R5111734/R6036587/R8145949 - RH 90495160
1.7D saloon/X17DTL from R2595226/R5111735/R6036588/R8145950 - LH 90495103
1.7D saloon/X17DTL from R2595226/R5111735/R6036588/R8145950 - RH 90495104
1.7D estate/1.7TD to R2588487/R5111734/R6036587/R8145949 - LH 90495159
1.7D estate/1.7TD to R2588487/R5111734/R6036587/R8145949 - RH 90495160
1.7D estate/1.7TD from R2588488/R5111735/R6036588/R8145950 - LH 90495103
1.7D estate/1.7TD from R2588488/R5111735/R6036588/R8145950 - RH 90495104
Shock Absorbers
Front (single)
1.4/1.6 72118402
1.8/2.0 exc. SRi, Sport, GSi 72118403
1.8/2.0 SRi, Sport, GSi 72118404
Diesel exc. Sport 72118403
Diesel Sport 72118404
Shock Absorbers
Rear (single)
Hatch/saloon exc. Si/SRi/Sport/GSi 72118762
Hatch/saloon Si/SRi/Sport/GSi 72118765
Convertible 72118762
Estate with manual levelling system 72118764
Steering Ball Joints
All models 90297863
Steering Rack Boots
Saginaw power steering (pair) 26024585
ZF power steering (kit) 90442111
Steering Racks
Manual steering 1.4/1.6 R1100007
Manual steering - All diesel models R1100008
Power steering Saginaw (exc. GSi) R1100001
Power steering ZF (exc. Sport/GSi) to T2782094/V5099313/V8001879 R1100011
Track Rod Ends
All models LH side 90369704
All models RH side 90369705
Wheel Bearings
Front
1.4/1.6 man. exc. Convertible to '93 (64mm) 90486458
1.4/1.6 man. exc. Convertible from '94 (66mm) 90510544
1.4/1.6 man. convertible/auto to '93 (72mm) 90486460
1.4/1.6 man. convertible/auto from '94 (66mm) 90510544
1.4/1.6 auto to P5077914/NE299999 (64mm) 90486458
X1.4XE/X1.6XEL (66mm) 90510544
X1.6XEL (74mm) 90510542
1.8/2.0 to '95 90486460
1.8/2.0 from '96 90510542
All diesel models to '95 90486460
All diesel models from '96 90510542
Wheel Bearings
Rear
All models exc. ABS brakes 9120129
All models inc. ABS brakes 9120128
Braking systems
Brake Calipers
1.7TD - RH R1740033
1.7TD - LH R1740032
Brake Calipers
Remanufactured Rear
Brake Cylinders
Rear Wheel
Front (axle set)
Rear (axle set)
Brake Discs/Drums
Rear (single)
Brake Pads
Front (axle set)
Brake Shoes/Pads
Rear (axle set)
Handbrake Cables
Air intake.
Airflow Meters
C20NE 90510153
C20XE '92 93178598
Engine
Cylinder Heads
Remanufactured
X1.7DTL R1230051
Camshaft Sensors
C20XE 90510656
Crankshaft Sensors
C20NE '92 90493864
C16NZ 17087249
X1.6SZ 17095232
X17DTL 90540891
Knock Sensors
1.4 16v 10456240
X16SZ 10457220
C20XE 90510281
Lambda Sensors
1.4 16v 25164596
C18XEL 90411959
C20NE 90397524
C20XE '92 90009053
X14XE 90541440
X16XEL 90541301
Cooling system
C2.0NE 90486320
1.7D 90421905
X1.7DTL 90510638
1.7TD 90421810
Radiator Top Hoses
1.7D 90421900
X1.7DTL 90570080
Radiators
1.8/2.0 90443392
1.7D 90443465
X1.7DTL 90510645
Water Pumps
Transmission
CV Joint Boots
CV Joint Kits
Remanufactured
Driveshafts
Remanufactured
Clutch Cables
1.7D 90334418
1.7TD 90373558
Clutch Kits
1.4 8v R1520051
1.4 16v 93185886
X1.6XEL R1520053
1.8 to '95 R1520057
1.7D R1520046
1.7TD R1520060
Exhaust system
Exhaust Front Pipes
X1.4NZ 93181140
Alternators
Batteries
Aftermarket
Batteries
OE
Starter Motors
X1.7DTL R1040028
Headlamps
Indicators
Front
Rear Lamps
Service parts
Air Filters
1.7D 90486883
Fuel Filters
Fuel Pumps
Glow Plugs (single)
Oil Filters
1.7D 90442434
1.7TD 93182630
X1.7DTL 90510935
Pollen Filters
All models 93182435
Wiper Blades
Rear hatch 90444836
Cam Belt Kits
Cam Belts
1.7TD 94385561
Distributor Caps
C1.4SE 90350997
C2.0XE 90442358
C2.0XE 90008612
Fan Belts
1.4/1.6 93181708
C1.6SE 90444312
16mm 90495054
18mm 90447868
20mm 90495055
22mm 90447867
18mm 90278577
20mm 90495045
22mm 90278579
Front
Shock Absorbers
Front (single)
1.4/1.6 72118402
Shock Absorbers
Rear (single)
All models 90297863
Steering Rack Boots
Steering Racks
Track Rod Ends
Wheel Bearings
Front
Wheel Bearings
Rear
