Will a calibra electric sunroof Mechanism fit a Astra Mk3?
Answer would be appreciated as I have one in the garage
How does the panel come off?Paul0 said:Im almost certain it will fit no problem, have a goits a 2min job to remove the panel
found one at the scrappy and adopted it
job done!I dont know cause I have a 92, but I assume they are similiar (assumption being the mother of all .....) there are only two wires from the motor, connect one to earth, the other to a suitable positive (I have connected mine to the interior light feed for now as it doesnt draw many amps) and make sure that the sunroof is wound all the way back, do the same with the motor or you end up with it stopping in all sorts of weird positionsHendry said:sorry to hijack your thread bud
but:
on a 97 1.6 LS would it be a case of "plug 'n' play" by just fitting the motor and surround/switch and the sunroof would be converted to electric??
oh, on topic, a Vectra B electric sunroof motor works in the mk3 as a straight fit.
