changing a front spring.
scotland
hello, as above i,am changed the front spring on my astra. every thing is disconnected, last thing is to seperate the hub from the shaft. the other side came apart easily but not this side. will i need some sort of puller to split it apart.. any help will be great. cheers steve.
Was cheaper than that, but first image.
There are some real cheap ones which might be fine if you aren’t going to use them much
Can probably knock them out, but this is just a bit more controlled if they’ve seized on the splines
Good luck
