electrical problem
behind the wheel
electrical problem dash lights ect
When i switch my lights on my rev counter drops to zero but switch them off and the rev counter works as it should, also the dial lights dont come on when lights are switched on
could be a couple of things there.the earth and ignition main feed switch(ignition barrel)
is bad for feckking up,easy way to check is with engine running,remove steering surround and feel back of plug,(on back of barrel)if its warm there is a bad connection there,can cause lots of funny dash problems like heaters not working,dash lights ect.think they are about 20 quid .oh ye,mine nearly went on fire from this fault!!!
