Fan assisted ovens!
funny i just helped my mum do hers over christmas in the back is a panel remove that and it will be a heater coil or whatever you want to call it its more or likely this and you can get one from http://www.espares.co.uk/ takes like 3 minutes to fix once part arrives.
my fan oven is the other way its too hot lol.
you cant leave anything in or turn oven to temps you would with a different oven. its crazy!
when we first got it the mrs was burning everything and couldnt understand it lol
some times the thermostat in them is tucked in really rubbish area and they tend to over heat might be worth a look x30xe van
or could be your still cooking at package temps conventional ovens cook food at like 20 degrees lower for example if my food said 180 my oven says 160 its usually in the manufactures book.
Yeah noticed a lot more packaging now gives the lower temps for fan ovens.
Had ours for over two years, a stoves one, superb oven.
ive figured it out,my fan works but then stops and struggles to turn,so i think its the bushes on the motor are dirty or broken,so the fan isnt blowing the hot air from the element around it.
Reading packets? Is it just me that cooks everything on 200c then?
