the large connector with 2 thick black wires goes to either side of your rear window (one wire off the window will be an earth and the other will be the original feed which you use later on)
the other connector, iirc, has one thick black wire and a thin red/white wire, the thick black wire connects to the original feed to the rear window and the thin red/white wire needs a 12v supply, can't remember if I connected this to the leccy aerial wire or to the rear window feed wire though!
The box can be mounted in the space where the original wing mounted aerial was (if you had one mounted there!) and the aerial wire its self should screw straight onto the box.
