when i bought my astra gsi the guy said it had a stage 3 chip and a set of kent fast road cams. Is this a good mix or a bad mix?... im not sure what stage should be used 1,2 or 3?
Xe, I just want to no untill my let is fitted. i do know the xe that is in there is mega lumpy on idle it revs up and down on its own when its cold but not to bad when its hot but still lumpy. any idea what it could be?
yea i could try that. some times i try puting my foot down and it jerks like a bad miss fire and soon clears in a split second :s but it only happens when i put my foot on the accelerator.
im also sure its over fueling cuz it jerks at low speed like if i got a kangaroo petrol lol. so i think its using more fuel than it should... also if i drive at 60mph i drives like a dream just not at low revs
what about the temp switch by the manifold? do u think that will cause it to over fuel.
also what about the throttle position censer? do u think its worth getting a new1 as i do know when the car is just on tick over i unplug the TPC and it dont make any difference at all then if i put it back in there still no difference
