x14nz running issues
L13
Loughborough
My son's car is causing headaches with its running issues, he's posted on here about the TPS throwing up faults but i thought i should try and give a better picture of the faults and see if anyone has any ideas.
Its a 1997 5 door merit hi-torq, single point injection x14nz.
When we bought it the previous owner, (some garage in Mansfield) stated there were some running issues initially with the car when they got it, and they replaced al the sensors and some other stuff, but could not get the emissions down, so thy swapped the engine for one from another 1.4 astra they had which pparently fixed the issues.
Only got to drive around the lot as we were short of time but it seemed fine and as the underbody of it was good we decided to buy it.
No real issues on the way home apart from a sticking brake and the fact it was gutless according to my son. But when i got to drive it, i found 'gutless' actually meant 'without any power whatsoever'.
I decided it was time for a proper look... turns out a lot of the 'new stuff' was still in boxes in the boot, so we fitted those, no real improvement. We fitted the spare distributor as the one on it was burnt badly and the rotor arm had disintegrated, ...a small improvement... but still no power.
We have since replaced the vacpipes, fitted any new sensor we can, and timed it up properly, it will run at the correct timing settings but bogs down on acceleration to the point of nearly stalling, but if you then lift off the throttle it smoothes out and runs nicely, you just can't accelerate quickly... or at all really. the only way it accelerates at all is if you advance the ignition quite a bit, but then it idles high.
And every morning it throws up a TPS fault code and wont run very well at all until its warmed up.
TPS has been changed three times, everything has been changed at least once, it just keeps doing the same thing.
One for the older generation, It runs exactly like a chevette or viva does when the stromberg carb diaphram is worn out or the piston spring is missing, like the piston shoots up too quickly and delivers too much air and it goes breathless... if anyone remembers that....
But i cant see what would cause that on these single point injection things.... any ideas?
I've probably missed something obvious that's clearly apparent to someone on here, i dont mind if i'm being dumb, i just want it sorted, if only to stop my son harrassing me with his car :)
Thankyou for your time, any advice is much appreciated.
Would it be something to do with whatever passes for vacuum advance on injection engines? As it does seem to behave like the vac advance isn't working due to running ok when you ease off the throttle but bogging down on acceleration...could that be it?
This may be true as some vac pipes seemed to be in the wrong place, one from the injection unit 'top hat' wasn't fitted and there was one running to the air filter from the base of the injection unit, which seemed wrong to me. It would help having a diagram of the correct routing of all vac pipes.
As far as the engine swap goes, I'm not sure they actually did it, as the reason they said they did it was to bring the emissions down for the MOT. Which seems an excessive 'fix' ... And now the car has just failed it's mot...on emissions...
Hmmm....
Anyway thanks for your help, if you do have a diagram of the correct routing that would be most appreciated.
Thanks
So this issue is fixed. After trying pretty much everything, and replacing all sensors, vac pipes which made no difference at all, I decided to pop out the injector. It literally did 'pop' out and the o ring went flying, I recovered the offending o-ring from where it landed, cleaned up the injector and put it back. Immediately it changed everything. Tickover back to normal, flat spot gone and it passed the MOT no trouble.
Just in time for Xmas brilliant.
I'm about to try to sort a misfire on my car - was thinking it could be an ignition issue but am wondering about injector(s) now.
Always worth checking everything out, We've had this issue for a while and couldn't fathom it, I messed with the injector as a ' well it can't hurt' type measure and lo and behold it was that ...
